John-1208407 Posted March 16, 2021 Share Posted March 16, 2021 I have recently resurrected a Scalextric C.1007 – Formula One outfit for my grandchildren. It was bought in the early 1990’s and is working perfectly. The only problem is that I don’t seem to have a piece of track that allows me to fit the 16v Powerbase properly. The Powerbase is working fine but I can’t connect both tracks as none of the track sections have the necessary, moulded connections opposite each other – any that have the connection spaces have 2 ‘offset’ on the underside. Any advice if there is a specific track reference that has the necessary connections?Many thanks. Link to comment Share on other sites More sharing options...
Andy P. Posted March 17, 2021 Share Posted March 17, 2021 You likely have "Classic" track and are trying to connect it to a "Sport" powerbase.You need the C8222 adapters. A picture would make sure my understanding is correct.... Link to comment Share on other sites More sharing options...
John-1208407 Posted March 17, 2021 Author Share Posted March 17, 2021 Thank you for your thoughts, Andy P.I attach some photos which, hopefully, will clarify the problem.John Link to comment Share on other sites More sharing options...
John-1208407 Posted March 18, 2021 Author Share Posted March 18, 2021 Andy PI replied to you earlier and got a note to say my post had been received and was being checked. Did the response arrive?John Link to comment Share on other sites More sharing options...
John-1208407 Posted March 19, 2021 Author Share Posted March 19, 2021 Andy PThanks for your thoughts. I'll attach 1 of the photos to this post to see if the 3 I attached were, maybe too big. If successful, I'll post the others.John Link to comment Share on other sites More sharing options...
Andy P. Posted March 21, 2021 Share Posted March 21, 2021 Yes that is a classic powerbase. If you want to use modern track you need the adapters I mentioned.After looking at the pictures though I don't understand why you circled parts in red.Maybe I don't understand your problem after all? Link to comment Share on other sites More sharing options...
John-1208407 Posted March 21, 2021 Author Share Posted March 21, 2021 API haven't explained my issue very well. I'm happy to stick with the classic track.The issue is that the pins on the powerbase unit only align with a connection on 1 of the tracks - not both and I wanted to know if there is a special track reference that will allow the powerbase to connect to BOTH tracks?Photo 1 shows the C160 track with the powerbase connection points ringedPhoto 2 is a bigger version of a connection point.Photo 3 shows the powerbase aligned with the underside of the track. The bottom track will fit perfectly but there is no corresponding connection on the 'upper' track?Thanks for the help. Link to comment Share on other sites More sharing options...
Bazzer1707822406 Posted March 21, 2021 Share Posted March 21, 2021 API haven't explained my issue very well. I'm happy to stick with the classic track.The issue is that the pins on the powerbase unit only align with a connection on 1 of the tracks - not both and I wanted to know if there is a special track reference that will allow the powerbase to connect to BOTH tracks?Photo 1 shows the C160 track with the powerbase connection points ringedPhoto 2 is a bigger version of a connection point.Photo 3 shows the powerbase aligned with the underside of the track. The bottom track will fit perfectly but there is no corresponding connection on the 'upper' track?Thanks for the help.JohnI think I understand your question and problem. The track section on which you circled the power connections is the classic track that was used prior to the powerbase style of connections. With the track that you show the power was applied to the track by two flying leads coming from a jumble of wires around the controllers and transformers, on the end of the flying leads was a rectangular plug that fitted into your circled areas. Your powerbase is from the late series of classic track, my guess is that in your collection of track there will be a section of track that has those connection sockets in line to match your power base. I had that same powerbase as you sometime ago but the classic track all went missing in a house move, I think we gave priority to the Sport track. B. Link to comment Share on other sites More sharing options...
Andy P. Posted March 22, 2021 Share Posted March 22, 2021 I don't think there are any posts on here with wiring older powerbases but I am sure there would be some to found online. It's fairly straightforward . You have a positive and a negative wire for each lane and they need to get power from the power jack...Like I said. Google "slot car track wiring" and it should show you something useful.. Link to comment Share on other sites More sharing options...
