Milkman rob Posted April 14, 2021 Share Posted April 14, 2021 Is problems with the digital Chip common? I have converted a few cars that’s have gone wrong almost straight away, they’re not exactly cheap to keep replacing Link to comment Share on other sites More sharing options...
Andy P. Posted April 15, 2021 Share Posted April 15, 2021 There are lots of variables when converting cars that are not DPR.The most common problems occur when converting older cars or non-Hornby cars as the motors pull too many amps and burn out the chips.Could you be specific in which cars you are converting with which chips?GregK on slotracer.online can repair almost any chip.-.. Link to comment Share on other sites More sharing options...
Milkman rob Posted April 20, 2021 Author Share Posted April 20, 2021 To be fair they are older cars or different makes mostly, although I have had a DPR easy change chip go wrong as well. With what you’ve said about the motors maybe if I update them it should be fine and change other makes to scalextric ones, I hadn’t thought of that. Link to comment Share on other sites More sharing options...
