CJ-814747 Posted July 2, 2021 Share Posted July 2, 2021 I have Hornby's last model of Thomas the Tank Engine and a few months back it was on its last legs and the gear went square. I bought new wheels, a new gear and new motors but the wheels are gear set that works with Hornby's last model of Thomas are out of stock. I need some help. When I add the motor to the belly plate of the loco chassis, it stops the middle wheel from turning and it lifts it up off the track, though the left and right wheels stay on the track. Is this a problem with the motor or the gear. I have tried tightening the motor, loosening it and it still won't work.The wheels, including the middle gear set, move on the track freely when the motor is removed but the motor stops chassis from working.I am a young modeller and I have no idea how to fix it. Please help me.Thank you :)CJ Link to comment Share on other sites More sharing options...
Going Spare Posted July 2, 2021 Share Posted July 2, 2021 Welcome to the Forum. Sorry to hear of the problem.Can you provide part numbers for the replacement components you purchased?Is the chassis of your loco exactly the same as the one illustrated on Service Sheet 349 which is downloadable via the Product Support section of the Support and Advice menu here? Link to comment Share on other sites More sharing options...
96RAF Posted July 3, 2021 Share Posted July 3, 2021 From what you are describing you may have the wrong wheel set for the loco frame. It also sounds like the motor doesn’t fit the old mount in proper alignment with the gear train.Often a later model may seem to be the same as a previous model but there can be differences in detail, making swapping parts impossible. Link to comment Share on other sites More sharing options...
RDS Posted July 5, 2021 Share Posted July 5, 2021 @CJCan you please upload a picture of your Thomas showing the motor as you have installed it.That should help to identify what is wrong. Link to comment Share on other sites More sharing options...
