ARC ONE and Sparkplug
Richard001
When Spark Plug came out one of my first thoughts was if you did the "brake mod" (use the search function here) on an ARC ONE i.e. remove the power to the rails and combine it with Spark Plug you would get very close to an ARC AIR.
The only problem I would see is getting the devices and APPS to play nice since you need 2 devices for the Spark Plug and one for ARC ONE.
If you used the Magic APP for ARC and connected it to a PC that should work fine.
Otherwise you may have to experiment to get it to work .
I don't think you would break anything. It just might not work.
