JAMES-1245295 Posted March 16, 2022 Share Posted March 16, 2022 I understand that there Airfix did use to have a model for the HMS Ajax, but it is no longer in issue. I am trying to track down a set. This was the ship my grandfather served on as an engineer during WW2 (a veteran of Dunkirk, the Russian conveys and the Pacific).Me and him used to love doing Airfix together. and having recently walked past a hobby shop I had a real rush of nostalgia! My grandfather passed a way a number of years ago but i was really keen to track down a set and complete it for old times sake.I've written to the Airfix customer service team, who unfortunately confirmed they no longer stocked this set. I was hoping that the Airfix community might be able to help. Link to comment Share on other sites More sharing options...
Sailorman Posted March 16, 2022 Share Posted March 16, 2022 James, You'll find many examples of unbuilt Airfix HMS Ajax kits for sale on ebay. Link to comment Share on other sites More sharing options...
KiwiKev Posted December 19, 2022 Share Posted December 19, 2022 This looks like a nice little kit. The main turrets need some raising, forward 4 inch mounts seem to need repositioning if the other models I've looked at are correct. The whalers positioned in front of the 4 inch mounts appear to need to go between them.Otherwise looks like a great basis for adding extra detail and photo etch. There are some 3D printed parts available but I'll try to use as much of the original model, as most of it looks pretty good, just needs the extra detail added such as port holes, hatches and doors. Happily there are only two molded ladder ways to remove.Checking the alignment of the molded port holes, there are a few out of line along the hull. Will try to straighten their alignment when drilling out These kits are no longer available new but I scored one cheap from an online sale, so if you're patient you should be able to find one too. Link to comment Share on other sites More sharing options...
Ratch Posted December 19, 2022 Share Posted December 19, 2022 Kev, is that a different fit to how the ship is portrayed or corrections?I have a couple more of these in the stash. Link to comment Share on other sites More sharing options...
Sailorman Posted December 28, 2022 Share Posted December 28, 2022 The turrets are not very good. I had originally built them straight from the box but I've gone back to work on them again. I'll try to post some pictures. You can actually get resin replacements - if you're willing to pay an arm and a leg - but I think you can re-work them quite easily. Link to comment Share on other sites More sharing options...
peebeep Posted December 29, 2022 Share Posted December 29, 2022 I seem to remember an 'accurising' article for Ajax in a 1960's edition of Airfix Magazine, also conversions to other vessels. Link to comment Share on other sites More sharing options...
KiwiKev Posted January 1, 2023 Share Posted January 1, 2023 Ratch, most of the models and drawings I've seen with the twin 4 inch show them spaced further apart, and with the cutter in between them, rather than forward of them. There is also an over head photo of Ajax in the Warship Annual of 2019(?) that shows the same. Can't be sure they weren't originally in the position on the OOB Airfix kit, but I haven't seen definitive proof of it yet. In the kit they seem to be in the positions of the original single 4 inch mounts, and I think the additional spacing was to reduce the chance of one hit disabling both mounts on one side.. Link to comment Share on other sites More sharing options...
KiwiKev Posted March 12, 2023 Share Posted March 12, 2023 I have made a start on detailing the main turrets for the Ajax. 1mm styrene sheet on the bottom both corrects the height and encloses barrel slots which otherwise run all the way to the bottom of the turret, which looks awful. I also ran the slots up into the top plates just a little. All this detail can be found by sneaking a peak at the various 3D printed replacement parts websites that often feature wonderful images from every angle. You could of course just buy their parts, but that may increase the cost of the project by a fair margin.A number of small styrene panels and wire lengths are glued on to simulate other detail, and very fine wire is run around the outside of the barrel slot to simulate the flange that lines them.I moved the barrel slots out slightly and then adjusted it to the right width with a styrene insert. All sounds very fiddly but usually I spend more time procrastinating about these steps than doing them, once you set aside some time they don't take so long.Also visible is the treatment I gave to the 4 inch mounts, closing up the slot, moving the barrels closer, cutting away the solid lower rear and simulating the loading tray. These little treatments all make a big difference, and get you on the way to making something close to the best models available in 1:700.The WEM PE also looks pretty stunning, so hopefully this will end up being another really good finished model to go alongside my Exeter conversion.Note also I've taken the time to smooth out any sign of the seam between the superstructure walls and the deck on top. This is really crucial on these older models if you want to add detail like doors, port holes and hand rails, and end up with a really neat finish. Link to comment Share on other sites More sharing options...
KiwiKev Posted March 12, 2023 Share Posted March 12, 2023 Two main turrets painted and in A and B positions. Need a bit of tidying up, but give an impression of what they'll look like in-situ. Link to comment Share on other sites More sharing options...
KiwiKev Posted March 16, 2023 Share Posted March 16, 2023 The bridge structure has been moved back a few mm from its original position. It appeared to be far too close to B turret. This required butchering the deck it sat on to remove the forward part of the locating plinth and inserting some replacement deck. Also a slight overhang on the front face was added (hard to see here) and the upper level screens were replaced with thin styrene of about the right height.The covered bridge was discarded and a replacement modeled out of left over PE and styrene. I decided to use the original 12 foot rangefinders as the PE ones were flat and I didn't think much would be gained by using them.Upper search light platforms have been added at the back of the bridge structure. The DCT gained a fair bit of extra detail too although it doesn't really stand out. There is a PE forward bracing bracket between the HACs mast and the DCT.A modified 4 inch mount from the kit is in approximately the right position forward. Link to comment Share on other sites More sharing options...
KiwiKev Posted April 1, 2023 Share Posted April 1, 2023 Forward detail almost complete. Hull plating lines etched in, somewhat roughly admittedly. A lot of scratch built details added as well as some PE. Starting to come together well and should build into a very nice model. Link to comment Share on other sites More sharing options...
KiwiKev Posted April 20, 2023 Share Posted April 20, 2023 Almost done, just the Seafox float plane and some minor parts to attach, and some paint touch ups. Once a few modifications were made, detail and PE set added, this kit really came alive. I have rushed the end a bit, wish I had more patience, but when there's a window of time to do some work, I tend to want to maximize it. Link to comment Share on other sites More sharing options...
KiwiKev Posted April 26, 2023 Share Posted April 26, 2023 Basically complete, Seafox float plane onboard. Not my best work but an enjoyable kit to make. Link to comment Share on other sites More sharing options...
KiwiKev Posted April 29, 2023 Share Posted April 29, 2023 Some more views of the completed Ajax. Aft gun turrets and fire control position.Seafox float plane and crane arrangements amidships.Forward turrets and bridge; Link to comment Share on other sites More sharing options...
Pretty Mediocre Modeller Posted May 2, 2023 Share Posted May 2, 2023 Wow! Rigging on a 1/600 biplane, that's some good work there! Link to comment Share on other sites More sharing options...
KiwiKev Posted June 4, 2023 Share Posted June 4, 2023 The aircraft rigging comes with the PE set so I can't claim too much credit for that. Link to comment Share on other sites More sharing options...
Sailorman Posted June 4, 2023 Share Posted June 4, 2023 NIce KiwiKev. You've done a great job. Mine isn't a patch next to yours! Link to comment Share on other sites More sharing options...
