Batman vs joker
Tim-1277317
Hi Tim,
Just to confirm you are talking about this set correct?
https://uk.scalextric.com/products/micro-scalextric-batman-vs-joker-set-battery-powered-race-set-g1155m
A lane running on full power is usually the sign of a damaged controller or a wiring problem in the powerbase.
If you are able you should be able to careful open up the controller and look for loose wires or broken connections. The same goes for the powerbase.
If you don't want to attempt that try to get a replacement from where you purchased it or contact Hornby customer services at the link below.
As far as the car is concerned: There is likely something jammed (gears misaligned, guide blade not seated correctly) causing more friction or bad pick up.
It could also be the car needs maintenance:
https://uk.scalextric.com/community/advice/car-maintenance
Hair, dust and fluff can slow these cars down... a little oil goes a long way...
  • 2 weeks later...
