Andrew-350187 Posted January 26, 2023 Share Posted January 26, 2023 Have spayed a clear canopy using masks for the first time on 2 parts the masks work well and have crisp and clean frame Lines the main canopy the masks weren't so good and bled underneath slightly how can I sharpen lines without ruining the lot colour is Matt green 30 Link to comment Share on other sites More sharing options...
Sailorman Posted January 26, 2023 Share Posted January 26, 2023 I usually run the end of a wooden toothpick along the edges of the mask to ensure the edges are pressed down tight so as to avoid bleeding.When it happened to me I had scraped the offending paint off very, very carefully with a scalpel. You have to be careful not to scratch the canopy itself. In my case though it was a very tiny bleed.Whatever you do try it out first on an old canopy - or at least on a bit of clear plastic ...don't try it on your model. Link to comment Share on other sites More sharing options...
Adrian-352009 Posted January 26, 2023 Share Posted January 26, 2023 If it's acrylic paint careful use of a cocktail stick might do the trick Link to comment Share on other sites More sharing options...
peebeep Posted January 26, 2023 Share Posted January 26, 2023 If it's acrylic paint careful use of a cocktail stick might do the trick This works with enamel as well, paint adhesion to transparent plastic is usually not as good as opaque. If the paint is a little stubborn moisten the end of the stick with a tiny amount of thinner. Polish up after with a swab.To avoid bleed, as well as burnishing you can also apply a small amount of clear varnish to seal the edges. Link to comment Share on other sites More sharing options...
Andrew-350187 Posted January 27, 2023 Author Share Posted January 27, 2023 Brill thanks guys got most of it off with the best tool in the box a finger nail will give the rest a go later, cheers Link to comment Share on other sites More sharing options...
