Coaster Posted April 25, 2023 Share Posted April 25, 2023 Not sure if this is a feature that had been modded already, but a sensor at the start of a pit lane that could be used similarly to the yellow flag option to automatically reduce the max power of someone coming into the pit lane Link to comment Share on other sites More sharing options...
Andy P. Posted April 26, 2023 Share Posted April 26, 2023 I presume you mean the digital pit lane and not the very old and out of production analog "Goodwood" pitlane with the physical switches in the track.In the digital pitlane it would require a major reworking of the electronics. There are really two avenues to approach it.One would be decoupling the pitlane from the rest of the layout and apply a constant, low voltage, say 5-6 volts. The problem here could be the voltage being too low to get the car over the lane change at the end. It would also mean you can't make the car "stop" which is required for a pit stop on the ARC system.The other option is with sensors and electronics that when tripped know the ID of the car and reduce power until a sensor at the other is tripped again.Neither is impossible but not trivial in any way and probably very expensive... Link to comment Share on other sites More sharing options...
Sealevel Posted March 16 Share Posted March 16 If you use the C7042 Advanced Powerbase + SSDC v5 you get Pit lane sensing, speed limiting, auto braking on pit entry. Also requires Pit-Pro (modified pit lane game). See http://ssdc.jackaments.com/products.shtml . Link to comment Share on other sites More sharing options...
Andy P. Posted March 17 Share Posted March 17 I have never tried it but I reckon if you isolate the pit lane and then apply say 5 volts from a battery pack that ought to slow things down.... That does mean losing contact to the powerbase though which may cause other problems... Link to comment Share on other sites More sharing options...
Sealevel Posted March 18 Share Posted March 18 The Pit-Pro mod of the Pit Lane Game adds a second sensor so that the software (SSDC) can slow the car in the pit lane. I think Riko or RichG were the ones doing the mods. Link to comment Share on other sites More sharing options...
Andy P. Posted March 18 Share Posted March 18 Riko Rocket stills supports it to a degree I believe... He can be found on the Slotforum.com... Link to comment Share on other sites More sharing options...
