chip fitting lion train pack
badgers
Generally I had no issues, just needs very delicate handling!
Lay the loco on its left side and remove one base screw as per instructions. The uncovered PCB needs pulling out just enough to remove the <awful> insulation tape wrapped around it and the blanking PCB. The latter can then be removed. Fit a (Next18-pin) decoder, e.g. R7345 HM7000-N18TXS and then wrap the decoder and original PCB with tape to insulate it up again (my preference is Kapton Polyimide Tape).
When refitting back into the loco, take care not to trap existing wiring. The loco is pre-fitted with a speaker so no need to worry about that side of things.
The biggest issue to watch is that this loco has amazing detail but comes with that is it's very easy to damage and break something off. My front coupling hook was already loose in the box and the whistle on top of the boiler I damaged when laying on its top side, hence my advice to lay on its left as this has less parts that could be damaged.
Overall, go for it, the loco is amazing with the handling caveats above.
