Delete points from design layout in Rail Master
Personally, I’d save the existing design as a new name, then change that new name.
You have to change the file name from one of the supplied layout names in any case, else it will be overwritten the next time you do an update.
Read page 97 of the RM manual for deleting track pieces.
First you have to open the track plan in the track plan 'Edit' screen.
IIRC you can use the mouse left button hold to drag a box around the items to delete. You can also hold down the shift key whilst left mouse clicking to select the items you want to delete. Then with the items selected use the 'Del' key on the PC Keyboard.
