Decal Problems
Looking for advice regarding issues over applying decals. When I have applied to the finished model when they dry you can still see the transparent part of the decal, it might be that they are old but wondered if there is a solution
Thanks Ratch
Basically need to apply a gloss varnish coat over the model if using matt paint and then apply the decals.
Do you recommend any type of gloss varnish / brand and if better as a spray or brush applied.
Cheer Rob
i use humbrol clear gloss found it to be ok, don't use it when its hot and really humid in summer or cold and damp (condensation on windows) in winter unless heating will be on till its dried i usually give it a coat in the morning giving it all day to dry since theres no heating on through night, it can turn white when drying but another coat in better conditions can usually sort this out, I've found doing two thin coats is better than one thick coat it can pool and go sticky in places underneath the kit as it finds its own level
