GWR Engine R3719 DCC 8 pin fitted
Shiv-379839
Hi,
I bought the GWR R3719 Dcc fitted engine 2 years ago, I've run it only 2 hours.
when it start it, it will move only 1 inch and stop, i can hear that the motor is on,
I've cleaned the wheels, tracks and pickups but it doesn't seem to work
not sure if its a problem with the chip or motor
i have 3 other engines all DCC fitted 4 pin that are running smoothly on the same track
can anyone advise what to do or does it need to be seen at the service centre
thanks
I have a loco that lurches forward a few inches and then stops whenever my Select controller is powered up. There are known compatibility issues between my controller and decoder; which now seems stuck in DC mode.
Does your loco respond to a 9V battery test ?
Shiv, R3719 is not a factory-fitted DCC loco, there would be an alpha suffix to the R number if it were.
So what decoder has been fitted and what controller are you using with what firmware revision?
And I take it that it was working 2 years ago?
PS. Only 1 carriage return needed between paras here, the forum software bizarrely adds a second itself.
