Booster Cables C252
Have converted my Old Classic track to Digital with track converters and Sport Digital control base unit
have converted a Mini Anniversary 3 pack to digital, wow so fast compared to older Classic cars. Can speed be adjusted as very fast for grandchildren to control!
Q: Can i still use the C252 Booster Cables as quite a large layout and suspect power is dropping on far side
Any advice would be appriciated
Many thanks
Mark
Hi There,
If you are using ARC PRO you can adjust top speed and acceleration in the the app.
If you are using the C7042 legacy powerbase there are third party software solutions that allow this but there is nothing out of the box.
Sometimes putting something under the trigger to avoid it being pulled all the way helps...
BTW: Chipped aka digitized cars will be twitchier than analog cars in analog mode.
Booster cables are fine in both analog and digital. Just make sure you don't cross the lanes.
Good luck!
