John208 Posted February 7 Share Posted February 7 Hi All. Today I added the Scotsman to my 'in progress' Easterner layout. All is broadly OK, I can control both trains on the app etc. However, two potential issues. Firstly the sound level on the Scotsman is completely overwhelmed by the sound on the William Whitelaw (WW), and secondly, now with the two trains I can no longer mute the sound for either loco via the app. Previously I could mute the sound for the WW. Therefore, if the WW is stationary in the siding it continues to 'puff away' and I cannot mute it. Any suggestions?Many thanksJohn G Link to comment Share on other sites More sharing options...
Fishmanoz Posted February 7 Share Posted February 7 For a start, have you installed the latest profile versions for each loco. The default sound level is lower on the newer profiles so not having the latest on WW may explain that problem. Check out the latest in the sticky at the top of the forum. Link to comment Share on other sites More sharing options...
John208 Posted February 7 Author Share Posted February 7 Thanks, I'll try that. I updated the newly acquired Scotsman, but interestingly the WW went back to Hornby for warranty, and came back 'louder' than when I first had it. I'll update the WW and see what happens. Link to comment Share on other sites More sharing options...
John208 Posted February 7 Author Share Posted February 7 Hi again. Tried that, but no difference. In the end I've just reduced the volume of the WW so it doesn't over power. I wonder if the WW has a bigger or better speaker? I've also emailed Hornby support to see if they can help. Thanks anyway for your suggestion. Link to comment Share on other sites More sharing options...
Ray-376212 Posted February 17 Share Posted February 17 I've got the same problem my William Whitelaw is definitely louder than my Blink Bonnie loco......I know you can alter the sound level but it seems a bit strange as I'm using the latest profiles. Link to comment Share on other sites More sharing options...
Moccasin Posted February 17 Share Posted February 17 Were both sets bought with pre-fitted sound decoders? Am just wondering if there’s a difference between the speakers in the two locomotives. Link to comment Share on other sites More sharing options...
Pendragon Sailing Posted February 18 Share Posted February 18 Its a relatively simple matter to reduce the sound levels. Either by moving the ‘global sound’ slider on the Locomotive Settings screen or by adjusting CVs 161-180, where the individual sounds for each Function can be set independently (see also pages 71-72 of the Manual). Link to comment Share on other sites More sharing options...
