gilbo2 Posted February 21 Share Posted February 21 One of my 10yr old R8247 V1 accessory decoders failed today after some short circuits, even though I've got a snubber circuit right next to it . Are the V2's more resilient against shorts than the V1's were? Link to comment Share on other sites More sharing options...
96RAF Posted February 21 Share Posted February 21 The hardware is the same, just a firmware change to enable the advanced functionality. It is wise to run separate track and accessory buses, then if a derail shorts the track the points/signal bus is not affected. If running both bus from a single controller then a circuit breaker is advised in the track bus. A snubber is no guarantee of protection against spikes but certainly helps damp them. Link to comment Share on other sites More sharing options...
gilbo2 Posted February 21 Author Share Posted February 21 Ok, that's a shame. Do you think its worth sending it back for repair or just get a new one? I do need to think about using my eLink for the points now, trouble is I've run out of USB ports. USB splitters were always frowned upon unless things have changed these days? Link to comment Share on other sites More sharing options...
96RAF Posted February 21 Share Posted February 21 Worth asking customer services, but if 10 years old they will likely baulk. USB splitters were frowned upon but you could try a powered hub. I simply added a multi-port PCi card to my tower PC, but not so easy on a laptop. Link to comment Share on other sites More sharing options...
gilbo2 Posted February 21 Author Share Posted February 21 9 minutes ago, 96RAF said: Worth asking customer services, but if 10 years old they will likely baulk. USB splitters were frowned upon but you could try a powered hub. I simply added a multi-port PCi card to my tower PC, but not so easy on a laptop. Ok, thank you Link to comment Share on other sites More sharing options...
