Pete aka Spanner Posted February 24 Share Posted February 24 Surely I can't be the only one who's having trouble with my much anticipated dongle. It arrived today.. I was quite excited to get it setup and see how good it was. (could be) I followed the instructions to the letter.. Linked fine and then asked to be updated (firmware) so I duly tapped the update button and instantly got a message saying update failed, firmware error (or something very similar) please try again... that didn't work.. I've powered cycled everything and now the dongle is showing as a "resettable device" which I can't do as I don't have the reset code... Seems I'm stuck already... Hornby select without update.. could that be an issue? Link to comment Share on other sites More sharing options...
Pete aka Spanner Posted February 24 Author Share Posted February 24 CURED!! I done a hard reset on the dongle, then re linked it to the app. It went straight through.. no update required, no code required.. and at least now I can see the dongle and it's reset code which has duly been noted down on a piece of paper which I'll probably lose in a day or so.. Such a shame the system only reads/writes HM7000 CV's.. Maybe I'm asking to much. 1 Link to comment Share on other sites More sharing options...
96RAF Posted February 24 Share Posted February 24 1 hour ago, Pete aka Spanner said: CURED!! I done a hard reset on the dongle, then re linked it to the app. It went straight through.. no update required, no code required.. and at least now I can see the dongle and it's reset code which has duly been noted down on a piece of paper which I'll probably lose in a day or so.. Such a shame the system only reads/writes HM7000 CV's.. Maybe I'm asking to much. Think about it. . . . The app reads Bluetooth decoders CVs over the air. The dongle passes app commands to the dcc controller which talks to legacy decoders thru' the rails, same as normal. To read legacy decoder CVs from the app you would still have to move that loco to the programming track if your controller supports service track programming. 1 Link to comment Share on other sites More sharing options...
Pete aka Spanner Posted February 25 Author Share Posted February 25 Confirmed, I was indeed asking to much... 😊 Link to comment Share on other sites More sharing options...
Ian-1314310 Posted February 27 Share Posted February 27 Many thanks for posting this, I was having the same problem as you. A Hard Reset worked as you advised. 2 Link to comment Share on other sites More sharing options...
