Alanburford9101 Posted February 25 Share Posted February 25 Hi I bought a used Flying Scotsman where the rear end of the tender raises up from the track. How should I adjust the drawbar to allow the tender to be flat on the track? Alan Link to comment Share on other sites More sharing options...
LTSR_NSE Posted February 25 Share Posted February 25 @Alanburford9101 - if you can post a photo of the drawbar/connection to show exactly which version of Flying Scotsman you have - that would aid better solutions. Link to comment Share on other sites More sharing options...
atom3624 Posted February 25 Share Posted February 25 It sounds as if the drawbar has either been bent, or has been replaced the wrong way around. Al. Link to comment Share on other sites More sharing options...
Alanburford9101 Posted February 25 Author Share Posted February 25 This is what it looks like. Should I bent it upwards to get more pressure at the rear of the tender? Link to comment Share on other sites More sharing options...
LTSR_NSE Posted February 25 Share Posted February 25 Yes - the drawbar should be absolutely flat between the two screws. 👍 Link to comment Share on other sites More sharing options...
atom3624 Posted February 25 Share Posted February 25 Drawbars are cheap to purchase, but be careful - only bend slowly and little-by-little. Totally agree, should be flat. Make sure also the bar fits over the should of the screw and tighten as so - permitting free movement of the drawbar - looks like it me be jammed under the shoulder of the screw in the photo, might be wrong. Al. Link to comment Share on other sites More sharing options...
