andys steam dayz Posted March 30 Share Posted March 30 Would it be possible to do a update for the brakexsound to be attatched to the brake so when pressing the brake you get the sound of the brake rather than having them both as seperate icons on the hm 7000 app Link to comment Share on other sites More sharing options...
96RAF Posted March 30 Share Posted March 30 48 minutes ago, andys steam dayz said: Would it be possible to do a update for the brakexsound to be attatched to the brake so when pressing the brake you get the sound of the brake rather than having them both as seperate icons on the hm 7000 app You cannot re-map functions on the HM7K decoders. The best you have is auto-function sounds (F28) which squeals as you stop by default, but not as you brake (F27). Link to comment Share on other sites More sharing options...
Ighten 1707822464 Posted April 3 Share Posted April 3 Problem is if you change the acceleration curves too much to remotely get the loco near realistic running and stopping, you then seem to loose the auto squeal on braking. Link to comment Share on other sites More sharing options...
