Trainman1974 Posted April 5 Share Posted April 5 hi all, I have a bachmann class 66 with a HM7000 21pin TXS decoder, im currently having issues with it Im trying to run the loco in DCC mode I can control the lights and sound but I can't get the loco to move but when I switch the decoder back to bluetooth it works fine. Link to comment Share on other sites More sharing options...
96RAF Posted April 5 Share Posted April 5 48 minutes ago, Trainman1974 said: hi all, I have a bachmann class 66 with a HM7000 21pin TXS decoder, im currently having issues with it Im trying to run the loco in DCC mode I can control the lights and sound but I can't get the loco to move but when I switch the decoder back to bluetooth it works fine. Run thru' the troubleshooting guide.. One thing to check in the meantime is read CV19 which should be zero. If not set it to zero. The other thing to check is if you are using a long address that CVs 17 / 18 correctly translate that address - use an on-line calculator to check. 1 Link to comment Share on other sites More sharing options...
