Mulsanne88 Posted April 17 Share Posted April 17 I have just done my GWR mk3 test I started with power cars and one coach into and out of my siding negotiating 4 peco points in the process Then added one coach at a time until I reached 5 coaches Despite managing to lose one kinetic spring all worked ok BUT Using hunt magnetic couplings you must have at least a 2mm gap between coaches when on straight track otherwise they will foul when negotiating bends/points I guess most people buying these will have gone for the starter pack which includes couplings that are too short for mk3 coaches Hope this helps Link to comment Share on other sites More sharing options...
Martin-369195 Posted April 17 Share Posted April 17 I used the medium coupling from the WHWW starter set on my power and dummy car which worked on the points and R2 curves. I haven't got any coaches yet, however. Link to comment Share on other sites More sharing options...
Postman On The Rails Posted April 22 Share Posted April 22 On 17/04/2024 at 09:14, Moccasin said: Just for balance, my four coaches coupled well last night. There is one that I need to keep an eye on -it suddenly uncoupled and I subsequently found an unconventional HST arrangement going around the oval (coach - dummy - power car - coach-coach-coach) I think this was down to poor/hasty track laying as the decoupling happened twice in the same place and a jolt from a larger than desirable gap could have caused it. I just tested my new arrived BR MK3 all coupled fine and the exception was the buffer car to standard randomly uncouples at different speeds and at different locations, I did notice that the arm wasn’t dropping into place no matter how jiggly I got with it, it seems to stick in the raised position occasionally. Link to comment Share on other sites More sharing options...
Rallymatt Posted April 22 Share Posted April 22 I noticed on my 50’ Stanier one end was a bit reluctant to couple and on close inspection the metal hook was ever so slightly bent preventing the two couplings working together. Tiny tweak and issue solved. Might just be worth a closer look on anything not coupling correctly. 1 Link to comment Share on other sites More sharing options...
