geoffb41 Posted November 13, 2012 Share Posted November 13, 2012 just doing my track design in railmaster and need to add a diagonal diamond crossing between four sets of points.The design section shows horizontal and vertical crossing but i really need a diagonal one.Anyone know how i can do this rgds, geoff Link to comment Share on other sites More sharing options...
LMSTim Posted November 13, 2012 Share Posted November 13, 2012 The four diamond crossing in the design section should allow you to do pretty-much anything you want. The problem is, we can't see your design so it's a bit hard to help you. Play with it some more, and if you get really stuck, just send a Help Request from within RailMaster, which also sends your plan. Link to comment Share on other sites More sharing options...
St1ngr4y Posted November 14, 2012 Share Posted November 14, 2012 Geoff, I think what you need to do is place two diagonals on the same square to form a X (in computer terms a forward slash and a backslash) then you can place your 4 points on the four ends they provide. I had the same problem when I wanted to represent a double-slip point. Ray Link to comment Share on other sites More sharing options...
geoffb41 Posted November 17, 2012 Author Share Posted November 17, 2012 thanks ray did the trick for me geoff Link to comment Share on other sites More sharing options...
