Sly401 Posted April 24 Share Posted April 24 So far I have fitted 4 HM7000 decoders, one of which continues to give me trouble. Problem - Loco moves off smoothly until it reaches a certain speed , then it suddenly slows down to something like half its (pre hitch) speed if the control is set high then it accelerates smoothly all the way to the speed set. When decelerating it is smooth until it hits a particular speed ( I would say it is the same as when accelerating ) then it jumps up to around double its (pre hitch) speed. I can drive it smoothly and consistently if I keep the speed below the hitch point ( around speed step 60) but of course its all low speed stuff. If I drive it though the hitch its top speed seems slower than I would have thought Consistent hitch whether using App or NCE powercab DCC I observe an increase in amps on the NCE whenever it passes through the hitch Things I have tried, re-install profile install a different profile reset CV's Speed steps 28, 128, custom speed step table Motor tune (auto) Tried various emf and PWM settings Tried different start mid and High settings Fitted a different motor to the loco no difference Checked the idler gear not split, and motion smooth I had thought that this was something to do with shunting mode or brake function but not so sure now. This loco has the chip hard wired, does that invalidate the warranty ? Any ideas to try ? Thanks Paul G Link to comment Share on other sites More sharing options...
Britannia Builder Posted April 25 Share Posted April 25 This is a strange problem, but given all the things that you have tried it does seem to be a faulty decoder. It appears that when it reaches a certain output voltage some alternate path opens up to drain some of the current. I don't think that wiring the decoder directly would invalidate the warranty - I should return the decoder to Hornby. Regards, John Link to comment Share on other sites More sharing options...
96RAF Posted April 25 Share Posted April 25 I would examine the complex speed table CV values to see if there is an anomaly in speed step progression, especially at the 'hitch' point. Normally chopping the plug off will mean the warranty is void as Hornby cannot plug it into their system to check it out. You can but try George on the direct email address and see what he says. Link to comment Share on other sites More sharing options...
