oldmodeller Posted May 3 Share Posted May 3 Is it because I'm old and have lost my grip or does anybody else have problems getting paint out of a dropper bottle? I have had to resort to using a pair of water pump pliers to squeeze the bottle as I cannot squeeze it by hand. While mostly successful this method can lead to the ketchup bottle syndrome- you bang and bounce and squeeze the bottle, first none will come and then a lottle. Why are these bottles made so thick? Link to comment Share on other sites More sharing options...
Ratch Posted May 3 Share Posted May 3 I use a cocktail stick to re-open the hole, which can become blocked with dried paint. Link to comment Share on other sites More sharing options...
DoubleD Posted May 4 Share Posted May 4 I always like to add a ball bearing to dropper bottles to aid stirring.I never have any problems getting the top off a Vallejo bottle but really struggle getting the Humbrol top off Link to comment Share on other sites More sharing options...
Irishmail Posted May 4 Share Posted May 4 I have a couple of Humbrol dropper bottles and I have found that the plastic used is not as flexible as the Vallejo ones. I always keep a couple of bits of stiff wire to clear any blockages in the nozzle. Link to comment Share on other sites More sharing options...
oldmodeller Posted May 4 Author Share Posted May 4 Seen and done this and bought the postcard. doesn't answer the original query about not being able to squeeze the thing Link to comment Share on other sites More sharing options...
Marto Posted May 5 Share Posted May 5 I think the Humbrol stuff is a lot thicker (paint and bottle) then the better quality Vallejo. I've no issues with squeezing the Humbrol one, maybe your paint is drying up inside? Link to comment Share on other sites More sharing options...
oldmodeller Posted May 5 Author Share Posted May 5 No they are almost brand new - ordered from airfix this year Link to comment Share on other sites More sharing options...
john redman Posted May 5 Share Posted May 5 I have the same problem. Some seem to have a squeezable sweet spot where the plastic is thinner, but those aside they are tough to squeeze. I may start decanting them into empty Vallejo bottles. Link to comment Share on other sites More sharing options...
oldmodeller Posted May 7 Author Share Posted May 7 I think I will just remove the tops and use a brush like the tinlets Link to comment Share on other sites More sharing options...
Dominic Thomas Posted May 9 Share Posted May 9 As John Redman says above, I have found that there is a spot which is easy to squeeze. I’ve found this on all the Humbrol paint bottles I have used. The difficulty is finding it. Link to comment Share on other sites More sharing options...
