Length Of Track
Lancastrian
Hi
I am about to set up a layout for my live steam 'Scotsman'. I notice in the LS Operator's Manual there is an oval of track with given measurements. Now here is what some of you may believe is a daft question, but to me the only daft question is the
one that you don't ask.
Is there a technical reason for this 'length' of track and if so, if I was to use the same length of track but with a more rectangular layout rather than the suggested oval would that be suitable without any problems.
I
am sure that the answer is yes it is will be alright, but I just want to be absolutely sure before I start.
Many Thanks
Head on over to my blog and you will see that track length isnt an issue. BUT, if you want to go for a larger layout, you need to make sure you have VERY good connections to the track. A Power Bus is recommended (each section of track then draws power
from the bus, ensuring a consistent supply).
craigsgardenrailway.blogspot.com
  • 1 month later...
