Lee Weeman Posted July 15, 2015 Share Posted July 15, 2015 For every single model I have built, I seem to always make an error in fixing the canopy onto a model. I would paint the area where the canopy would fit, leave this paint to dry overnight to ensure its dried enough, and use the Humbrol Liquid Poly against that painted area and attach the canopy.Problem Im getting is that I see smudging, and its very annoying as I have put time into most models, and then, to be ruined on the very last part. Can anyone give me any pointers or advice? Thank you. Link to comment Share on other sites More sharing options...
Gadfly Posted July 15, 2015 Share Posted July 15, 2015 Hi,You could try a couple of things. Humbrol make a product called 'Clearfix' especially for fixing canopies and clear parts.An alternative is to use regular white PVA glue. Both work well in my experience.If you are using the liquid poly try cleaning the paint off of the plastic so the glue is Bonding plastic to plastic and apply the glue sparingly.let us all know how you get on..CheersGF Link to comment Share on other sites More sharing options...
Ratch Posted July 15, 2015 Share Posted July 15, 2015 Don't use superglue (cyanoacrylate) as this will fog the canopy. Link to comment Share on other sites More sharing options...
richard baker1707820250 Posted July 15, 2015 Share Posted July 15, 2015 Hi, as Gadfly said, i would use pva it is also a good way to fill any gaps around the canopy. Rich. Link to comment Share on other sites More sharing options...
Lee Weeman Posted July 16, 2015 Author Share Posted July 16, 2015 Ah, I didnt know humbrol make this 'Clearfix' Product. I will have to see how nice my wallet is and look into buying it. But I will try all other alternatives mentioned above. Thanks everyone for the tips, much appreciated. Link to comment Share on other sites More sharing options...
Dad Paul B Posted July 19, 2015 Share Posted July 19, 2015 The other thing with poly cement is that it is based on Methyl-Ethyl Ketone which dissolves the styrene to make the bond. This is also volatile so the vapour attacks the plastic as well. This is not a problem for the grey styrene pieces but it will etch clear stryrene and cause fogging even if you manage to keep the cement off the window surfaces.As mentioned 'Clearfix' works well and can be used to cover gaps. Link to comment Share on other sites More sharing options...
paul-muc Posted July 19, 2015 Share Posted July 19, 2015 For clear parts and small chrome parts I use simply clear gloss paint, a liitle bit thicker than normal. Apply it to the body with a fine brush, let dry about a minute, so there are no fumes and than fix the clear part. Let dry thorougly, that is overnight. If there are gaps between canopy and fuselage, you can add some more paint afterwards. Paul Link to comment Share on other sites More sharing options...
Jonathan Mock Posted July 20, 2015 Share Posted July 20, 2015 For every single model I have built, I seem to always make an error in fixing the canopy onto a model. I would paint the area where the canopy would fit, leave this paint to dry overnight to ensure its dried enough, and use the Humbrol Liquid Poly against that painted area and attach the canopy.Problem Im getting is that I see smudging, and its very annoying as I have put time into most models, and then, to be ruined on the very last part. Can anyone give me any pointers or advice? Thank you. The simplest, safest method it to use PVA white glue - it doesn't attack the plastic or paint and it has the benfit of filling any minor gaps around the edges that can be filled in with paint if needed. If you mess things up, you can wipe any excess off with damp cloth and start again. PVA is also cheap, a £1 bottle will last years. Link to comment Share on other sites More sharing options...
Russ1707821018 Posted July 20, 2015 Share Posted July 20, 2015 You can use CA (superglue) on clear parts without fogging if you first coat the part in Johnson's Klear (Future, Pledge multisurface finish, or whatever it's called now). This will also fill in any minor scratches and make the part look much clearer. If I was going to do this I'd probably use a gel type CA to give more working time. Link to comment Share on other sites More sharing options...
DavidJC Posted July 20, 2015 Share Posted July 20, 2015 I have got a bottle of Clearfix but not used it yet. I am still with PVA glue for canopies. Link to comment Share on other sites More sharing options...
Lee Weeman Posted July 25, 2015 Author Share Posted July 25, 2015 It seems to be, either to use PVA or Humbrols Clearfix. Im going to go with both of the choices made for me and test to which I find suits better. Thanks alot everyone on the advice, much appreciated. Link to comment Share on other sites More sharing options...
gary watson1707820320 Posted August 1, 2015 Share Posted August 1, 2015 You can use CA (superglue) on clear parts without fogging if you first coat the part in Johnson's Klear (Future, Pledge multisurface finish, or whatever it's called now). This will also fill in any minor scratches and make the part look much clearer. If I was going to do this I'd probably use a gel type CA to give more working time.Always give your clear parts a dip in Future 1st. They will really pop.As for glue, good old Elmers white glue. By the time it either yellows or it stops being glue I will be long gone. Link to comment Share on other sites More sharing options...
