Macdeg Posted December 12, 2015 Share Posted December 12, 2015 Hello, I just bought a wonderfull platinum set that includes a C7042 base for 6 cars. Everything works well in digital but once I switch to analog, lane 1 and 2 go the opposite way!!! :(Even if I change the direction of the lanes with only one power supply and lane by lane or with the two power supply connected changing the direction for both lanes. Nothing is working and the car continue to go in the opposite way. I've got a lot of analog car and I really want to have fun with those cars with my friends.Is it a problem with my C7042 (firmware 0.85) or did I miss something?Thank you for your answer !!Best regards, Nicolas Link to comment Share on other sites More sharing options...
Chris99 Posted December 20, 2015 Share Posted December 20, 2015 Hi,You've probably figured this out by now but setting analogue direction should be ok in v0.85The menu system is not intuitive at all. Drilling down in the platform menu to the inappropriately named "Gear" (renamed Dir'n in v1.09). Use the left/right arrows to select direction and hit enter after selecting it (not sure if "enter" is necessary but it won't do any harm)..If one doesn't reverse the direction, try the other one. My crib sheets should make navigation a bit easier:They are based on the unofficial v1.09 update, but are still useful for v0.85 although some abbreviations and menus have been changed>Menu flow chart>Abbreviations Try to update to v1.09 asap (see SSDC website) otherwise you may suffer missed laps. You will need a third party powerbase to PC cable ,which is not cheap, but it will also allow you to use sophisticated PC based race mangement systems and to do away with the Scalextric tower. http://www.pendleslotracing.co.uk/scalextric-digital-pc-usb-cable.html Chris Link to comment Share on other sites More sharing options...
Chris99 Posted December 20, 2015 Share Posted December 20, 2015 I forgot about these instructional videos which makes it very clear: Pressing "Enter" after selecting the direction is the key Link to comment Share on other sites More sharing options...
FrankRa Posted November 25, 2017 Share Posted November 25, 2017 Hi there, I just got the c7042 power base and I have exactly the same problem with analogue mode like Macdeg reported. Unfortunately the answer did not covered the problem at all. I already found out how to change lane directions, but it always changes both lanes simultanously, the opposite direction problem still exists... just vice versa. The car on lane 1 goes left, the car on lane 2 goes right. If I change direction, lane 1 goes right and lane 2 goes left. I've built the track with 3 straight lane changers, I don't know if that is relevant. The firmware is v.085. Maybe anyone know whats happening here.Thank you!Frank Link to comment Share on other sites More sharing options...
gorp Posted November 25, 2017 Share Posted November 25, 2017 same problem just on different posting - happens alot hereshort repeathad same problem now found here and guru at slotforum was no helpthen saw it reported first time at slotforum at end of augustand there were othersbelief was a last generation of apb manufacturing mistakeanyway solution that they thought would help was reversing wires on one laneposter never said if it worked but no futher complaints from himme just kept hitting buttons and then stuck it back back in boxdug out pb4 and glad and had best of both worldsnow running arc pro Link to comment Share on other sites More sharing options...
