JLBA Posted November 13, 2011 Share Posted November 13, 2011 Just about all threads regarding wishlist seem to be relating, naturaly, to rolling stock. Anyone have any other ideas, such as lineside stuff, buildings, vehicles, scenery, etc,etc? One i suggest is relating to a recent thread, platforms that have no indent on the top! Though it wouldnt benifit me as i scratch build them to suit. One i have mentioned before is some kind of semephore signal kit, so you can make a signal to suit your needs, obviously with a guide to signaling so you can get a realistic set up, also ground shunting signals. Oh yeah and some realalistic clour light signals, sorry to say it hornby, but the current ones are hidious! Im sure a young child could make a more realistic looking sign with a picture to copy and some odds and ends!! Link to comment Share on other sites More sharing options...
the ferret Posted November 13, 2011 Share Posted November 13, 2011 JLBA said:Just about all threads regarding wishlist seem to be relating, naturaly, to rolling stock. Anyone have any other ideas, such as lineside stuff, buildings, vehicles, scenery, etc,etc? One i suggest is relating to a recent thread, platforms that have no indent on the top! Though it wouldnt benifit me as i scratch build them to suit. One i have mentioned before is some kind of semephore signal kit, so you can make a signal to suit your needs, obviously with a guide to signaling so you can get a realistic set up, also ground shunting signals. Oh yeah and some realalistic clour light signals, sorry to say it hornby, but the current ones are hidious! Im sure a young child could make a more realistic looking sign with a picture to copy and some odds and ends!! Link to comment Share on other sites More sharing options...
the ferret Posted November 13, 2011 Share Posted November 13, 2011 Hi JLBA Signals are a bit of a fetish with me! Because the old semaphore signals were so tall, it was the sight of a post with red or yellow arm that was the first clue as to the presence of a railway as you travelled around. The answer to both kits of semaphore and accurate colour light signals is "YES!!!!!"try www.modelsignalengineering.co.uk or even just "MSE". This is run by Andrew Hartshorne who, if you place an order will give you some free advice regarding the siting of signals, how they work, and any sort of local knowledge. For example, he caters for all lines post and pre-grouping into British Railways and then modern day colour light arrays.Whether you are modelling LNER or Southern GWR, LMS, LNWR or LBSCR or KESR - whatever, Andrew will have suitable signal kits.I already have a superb kit of a Southern upper quadrant signal on a lattice LSWR post. It looks so good and only cost £9-50p. There are also operating levers and wires available to have control from your control panel.I favour the GEM wire in tube system available from GEM (3SMR) of Redhill. The MSE lever assemblies are very sophisticated and rather expensive. Link to comment Share on other sites More sharing options...
JLBA Posted November 13, 2011 Author Share Posted November 13, 2011 Hi the ferret, sounds like we have similar ideas, cheers for the reply!JLBA Link to comment Share on other sites More sharing options...
Choobacca Posted November 13, 2011 Share Posted November 13, 2011 I'd like to see a new version of the Hornby Booking Hall Station with a brick pattern molded onto the walls and slate effect on the roof. A new platform without the circular mark in the middle would also be good. Link to comment Share on other sites More sharing options...
Tony57 Posted November 17, 2011 Share Posted November 17, 2011 I would like to see electric operated working double track level crossings both barrier and gates, like Triang made in 1959 onwards. New Concrete and steel sleepered set track (GWR used steel sleepers in 1936). There is also a need for modern station buildings as well as the older types of the 4 main regions with modern paint jobs and logos as well as the old big 4 and BR. Link to comment Share on other sites More sharing options...
JLBA Posted November 17, 2011 Author Share Posted November 17, 2011 Thanx for the reply. like it!! Link to comment Share on other sites More sharing options...
mortehoe Posted November 17, 2011 Share Posted November 17, 2011 Tony57 said:I would like to see electric operated working double track level crossings both barrier and gates, like Triang made in 1959 onwards. New Concrete and steel sleepered set track (GWR used steel sleepers in 1936). There is also a need for modern station buildings as well as the older types of the 4 main regions with modern paint jobs and logos as well as the old big 4 and BR. Hi Tony57, I remember seeing steel sleepered track as recently as 14 years ago in the Scarborough area. I like your suggestion for concrete sleepers as well. Stations could be a problem, the rival firm do a great signal box ( art-deco style ) which is firmly Southern, then their Art-deco station is more akin to London Underground ( Wembly area ish ) so you just can't win. Link to comment Share on other sites More sharing options...
LCDR Posted November 18, 2011 Share Posted November 18, 2011 Although the level crossing is a good idea, it brings with it significant problems in that the double track geometry means a lot of fiddling to get it to fit. Rather than using the Tri-ang hot wire mechanism, I would hope that the operating motor would be mounted on a crossing keeper's cabin for gates and a relay room for a modern barrier version. I have three of the old Tri-ang ones and two have melted road deck. I would like to see the old 1960s Triang stations re-introduced. They (and the R145 signal box) were much more realistic with the moulded brick and contemporary windows and that grey concrete footbridge with the black hand rails that came in a kit, looked much better.I am not in favour of steel or concrete sleepers as these were rare on main lines before the 1960s and most steam period modellers I think would not want them. I can't see Hornby offering two or more different style rails, especially as the well known track maker in the West Country already offer these. Link to comment Share on other sites More sharing options...
mortehoe Posted November 18, 2011 Share Posted November 18, 2011 With the arrival of the 4-Vep ( Boo, Hiss, Rasp ), the pending arrival of the 5-Bel, of course not forgetting the rival firms SR EMU's, how about some 3rd rail ancillary buildings. The power to supply the 3rd rail has to come from somewhere, and of course it has to be distributed and monitored. Link to comment Share on other sites More sharing options...
mortehoe Posted November 18, 2011 Share Posted November 18, 2011 Oh yes I forgot, a carriage cleaning plant, and I don't mean a " bizzie lizzie ", with a mop and bucket. Link to comment Share on other sites More sharing options...
LCDR Posted November 19, 2011 Share Posted November 19, 2011 mortehoe said:With the arrival of the 4-Vep ( Boo, Hiss, Rasp ), the pending arrival of the 5-Bel, of course not forgetting the rival firms SR EMU's, how about some 3rd rail ancillary buildings. The power to supply the 3rd rail has to come from somewhere, and of course it has to be distributed and monitored.The competition do make a sub-station suitable for the 1930s schemes, but some other buildings would be useful. The large red-brick 'Cathedrals' made for the 1926 SE electrification are quite striking. There used to be one where the Catford Loop crossed the Mid Kent south of Catford, one at Dartford Junction and another alongside the station at Barnehurst. Link to comment Share on other sites More sharing options...
Choobacca Posted November 19, 2011 Share Posted November 19, 2011 I'd like a track powered illuminated buffer stop, or anything else with a light fitted. In fact just fit lights to everything Hornby :D Link to comment Share on other sites More sharing options...
mortehoe Posted November 19, 2011 Share Posted November 19, 2011 Choobacca said:I'd like a track powered illuminated buffer stop, or anything else with a light fitted. In fact just fit lights to everything Hornby :DHi Choobacca, I have 100yds of fibre cable which was going to be binned, not tried it yet for light guides, do you want some for your buffer stops ??????? Link to comment Share on other sites More sharing options...
mortehoe Posted November 19, 2011 Share Posted November 19, 2011 LC&DR said:The competition do make a sub-station suitable for the 1930s schemes, but some other buildings would be useful. The large red-brick 'Cathedrals' made for the 1926 SE electrification are quite striking. There used to be one where the Catford Loop crossed the Mid Kent south of Catford, one at Dartford Junction and another alongside the station at Barnehurst. Oh no they don't, most of the rotary converter houses are single story. The model you are talking about is about as Southern ( and Art deco ) as a Pontefract Cake. Link to comment Share on other sites More sharing options...
Choobacca Posted November 21, 2011 Share Posted November 21, 2011 Thanks for the kind offer Morthoe, I think I'll pass though. Fingers crossed Hornby will make a 'plug and play' buffer next year :)mortehoe said:Choobacca said:I'd like a track powered illuminated buffer stop, or anything else with a light fitted. In fact just fit lights to everything Hornby :DHi Choobacca, I have 100yds of fibre cable which was going to be binned, not tried it yet for light guides, do you want some for your buffer stops ??????? Link to comment Share on other sites More sharing options...
LCDR Posted November 21, 2011 Share Posted November 21, 2011 mortehoe said:Oh no they don't, most of the rotary converter houses are single story. The model you are talking about is about as Southern ( and Art deco ) as a Pontefract Cake.I beg to differ. The cast resin model I was referring to is a forshortened and simplified representation of a mercury arc sub station not unlike that at Chelsfield or Bexhill Central. Agreed it is reduced in size but superficially it is a representation of a Southern Railway 1930s style mercury arc station with an external transformer and switch gear (simplified in the model as made) within a chain link fencing enclosure. I was suggesting Hornby could counter this with one of the striking red brick 'Cathedral' rotary sub-stations, as used in the 1926 suburban scheme. These had the transformers originally in caged enclosures within and to one side of the building, until the 1954 'change of frequency' scheme when a few were given new transformers and had the rotaries replaced with mercury arc rectifiers inside. In the 1954 scheme the BR version of the mercury arc sub-stations were large rectangular single story buildings with flat roof, but with raised louvred ventilators above the rectifier tanks. The transformers were outside, and were larger than the old 1930s ones. I have made a considerable study of SR lineside electrification structures as used on the eastern section, and if Hornby wanted it I have scale drawings of these buildings. Link to comment Share on other sites More sharing options...
Fazy Posted November 23, 2011 Share Posted November 23, 2011 how about a nice trun table one that looks like a real one and not a toy the honrby one just lets down the locos they make now adays! and i am not willing to pay £200 for the other one you can bay which is dcc ready but not 00 scale! may be a smaler one for brench line would be nice Link to comment Share on other sites More sharing options...
JLBA Posted November 23, 2011 Author Share Posted November 23, 2011 Ive said before, ive google imiges hornby turntable before and its possible to make it look very good, however you have to ditch half the stuff youve payed for!! And cover alot of it up with overgrowth, ballast and stuff!! So realy, if you buy it and have to do all this then what a waste of money!! Link to comment Share on other sites More sharing options...
Fazy Posted November 23, 2011 Share Posted November 23, 2011 yep i now what you are saying i dont minnd doing the work after building loco kit and scrach built some but if you pay good money on a trun table it would be nice to fit it and used it not have to put X amout of hours in befor it can be used. and not end up with ahalf full box after Link to comment Share on other sites More sharing options...
walkingthedog Posted November 23, 2011 Share Posted November 23, 2011 There are other turntables available apart fro Hornby and h'jan Link to comment Share on other sites More sharing options...
the ferret Posted November 25, 2011 Share Posted November 25, 2011 I have made up two very old Airfix single track level crossing kits and using some soldered up brass parts I have made them work - across three tracks!! These are goods yard access and up and down main line. Now I have to make a leadscrew assembly driven by an electric motor fed by a simple relay circuit that can be interlocked with signals. It is coming together but slowly. But I will get there eventually! I picked up the level crossing kits dirt cheap at a local swap meet years ago. You don't have to buy everything new and expensive to achieve much.Ah'm no mean, jist carefu'!! Link to comment Share on other sites More sharing options...
the ferret Posted December 11, 2011 Share Posted December 11, 2011 Bearing in mind this thread is supposed to be "Anything apart from rolling stock", I would like to see more Southern Railway pre-cast concrete buildings, station platforms, signal boxes, must be ART DECO. The Art Decodesigns gave the otherwise Cinderella of the Big Four a surprising uplift into having a futuristic image of absolute modernity.The new signal box at Richmond was an excellent example of this.So how about some concrete section platforms, a "Space ship" signal box and smart sheds for emus even if they are 2-VEPs in blue livery!Somebody called Chris Leigh makes excellent white metal (looks just like pre-cast concrete) station nameboards. Link to comment Share on other sites More sharing options...
trainlover23 Posted December 11, 2011 Share Posted December 11, 2011 A spell check that works on the forum and a free dictionary to all members Link to comment Share on other sites More sharing options...
mortehoe Posted December 11, 2011 Share Posted December 11, 2011 the ferret said:Bearing in mind this thread is supposed to be "Anything apart from rolling stock", I would like to see more Southern Railway pre-cast concrete buildings, station platforms, signal boxes, must be ART DECO. The Art Decodesigns gave the otherwise Cinderella of the Big Four a surprising uplift into having a futuristic image of absolute modernity.The new signal box at Richmond was an excellent example of this.So how about some concrete section platforms, a "Space ship" signal box and smart sheds for emus even if they are 2-VEPs in blue livery!Somebody called Chris Leigh makes excellent white metal (looks just like pre-cast concrete) station nameboards. Hi Feret, work starts in the new year on my layout, the planned one is being shelved due to work commitments so a 12' by 4' condensed one is in the offing, but I too would like to see some Art Deco buildings from Hornby ( loyalty ), other wise it will be a case of buying a card version of one of the Chessington stations, and use as a pattern and try and scratch build. Then try and Surbiton-ise an available card model of Morden tube station. I think the model companies have ignored the Art-Deco/Modernist buildings, before anybody jumps down my throat, the main rivals offering will suit a Wembley area station.Since my layout is on the Surrey, Hampshire and Brazil borders, it will not do, it has to have that Odean Cinema feel about it. I know where to get the concrete fencing, foot bridges, platforms etc, again it would be nicer to be loyal to the company. Link to comment Share on other sites More sharing options...
