Topcat900 Posted January 31, 2017 Share Posted January 31, 2017 Just upgraded one of my f1 cars to digital and it will not activate the lane change track? What am I missing? Link to comment Share on other sites More sharing options...
Blagard Posted January 31, 2017 Share Posted January 31, 2017 Did you wire in the LED? That is what signals the Car ID and the Lane Change to work. Edit: If you did, did you wire it the right way around, it is after all a diode so it has to be wired in the right way around. Link to comment Share on other sites More sharing options...
Topcat900 Posted January 31, 2017 Author Share Posted January 31, 2017 No. Is it already in the car chassis? Link to comment Share on other sites More sharing options...
Blagard Posted January 31, 2017 Share Posted January 31, 2017 Ah! got you. You upgraded with the Digital Plug Ready system. My bad I was thinking C7005! Assuming you have a full digital setup that is already working and it is the only car you have that fails to trigger the lane change then it most likely a duff module. Link to comment Share on other sites More sharing options...
gorp Posted February 12, 2017 Share Posted February 12, 2017 If is only toy not activating changer,try cleaning led eye with breath and tissue.Have had cars fail before due to track dirt and just needed cleaning.And if happens with chip that you solder in,push it out a little more and clean.If changer fails with all the cars, clean it. Link to comment Share on other sites More sharing options...
gorp Posted February 12, 2017 Share Posted February 12, 2017 forgot to add and it would not let me edit postIn all cases you must have a half straight or longer before changerso that toy will be straight when it passes track eye. Link to comment Share on other sites More sharing options...
