Peter Ruifrok Posted February 11, 2017 Share Posted February 11, 2017 I recently found out that the maximum number of instructions in a RM program is exactly 500. Any instructions in that program beyond the 500st are not seen by RM. RM behaves as if they do not exist. As a matter of fact in the line at the top of the screen where the instructions are shown as they are performed one by one, the last instruction is number 500. I must admit that 500 lines is a lot, but it does happen and I have not seen this max number anywhere advertised. Did anyone else experience this? Link to comment Share on other sites More sharing options...
Fishmanoz Posted February 11, 2017 Share Posted February 11, 2017 Interesting Peter. In the Loco ID not being recognized thread, KNAP was the first one in my memory to report a limit in programming steps. But there his limit is around 100 steps. And I don't think HRMS has ever admitted to any limit? Link to comment Share on other sites More sharing options...
Peter Ruifrok Posted February 11, 2017 Author Share Posted February 11, 2017 I am entirely certain about the 500 lines, but I run only a limited number of locs (I have only 10 locs defined in RM in total of which 8 turn up in the program). All are recognised. I don't think HRMS is aware of this, I haven't told them yet and it is nowhere mentioned in the Guides. Link to comment Share on other sites More sharing options...
Fishmanoz Posted February 11, 2017 Share Posted February 11, 2017 Will be interesting to see if they respond. They were online posting in another thread only minutes ago. Link to comment Share on other sites More sharing options...
KNAP Posted February 12, 2017 Share Posted February 12, 2017 Never counted steps. Just always exited after the same number not time related. I ony run about 36 locos with program but does not appear related to other issue,A way round is to split the program into 2 parts.HMRS have had my program for 5 months. I would suggest sending yours to them as they have not yet found out why there is a limit with my program. Link to comment Share on other sites More sharing options...
96RAF Posted February 12, 2017 Share Posted February 12, 2017 I would report it in again chaps, especially if you are already in dialogue with HRMS. Just tell them the new info. Link to comment Share on other sites More sharing options...
Peter Ruifrok Posted February 12, 2017 Author Share Posted February 12, 2017 I am trying to use the chain command and have cut the initial (too) large program in two parts (A and B). I have then created a new program chaining A and B. However, according to the Guide this cannot be run from within the program window, but must be run from the main screen. Can anybody tell me how to do that as I have looked everywhere on the main screen in vain. Link to comment Share on other sites More sharing options...
Peter Ruifrok Posted February 12, 2017 Author Share Posted February 12, 2017 BTW I have assumed that with the "program window" not the large programming window is meant (in which the actual programs are programmed line by line), but the small one on the main screen to which programs are loaded to be run. I have tried that small one on the upperside of the main screen but loading my chain program into that and running it made RM go into an eternal nothing..... Link to comment Share on other sites More sharing options...
Peter Ruifrok Posted February 12, 2017 Author Share Posted February 12, 2017 Can anyone remind me of the correct email address? Is this customercare@hornby.com? Link to comment Share on other sites More sharing options...
St1ngr4y Posted February 12, 2017 Share Posted February 12, 2017 Hi Peter,If your new program, containing nothing but two chain commands for programs A & B, you have saved as program C, then you should be able to see program C in the dropdown list of programs at the top left of the main screen. The large editing window is where you can't run a program containing CHAIN commands. When you run such a program in the main window, RM takes a while to merge the two programs into one ready for execution. Maybe you are busting another memory limit in trying to do this.Why don't you run them as two (or more) programs in a schedule, using RM's built-in scheduler?Ray Link to comment Share on other sites More sharing options...
RDS Posted February 12, 2017 Share Posted February 12, 2017 Can anyone remind me of the correct email address? Is this customercare@hornby.com? You are better to use support@rail-master.com for RailMaster related emails. Link to comment Share on other sites More sharing options...
Peter Ruifrok Posted February 12, 2017 Author Share Posted February 12, 2017 Hi Ray, I will wait a bit longer then, or otherwise try the scheduler. Thanks RDS, I will send an email. Link to comment Share on other sites More sharing options...
Peter Ruifrok Posted February 13, 2017 Author Share Posted February 13, 2017 I have sent the program and the accompanying log to Support who are now looking into the matter. As far as they know there is no limit set by RM so this may be a case of Windows 10 setting a limit. I have closed down all open programs (such as outlook and internet explorer) but this made no difference. Hadn't expected to either, but it does no harm to try. The chain commands makes the program "hang", so this may be a second symptom of the same underlying problem. I haven't figured out how to use schedules yet. Not much about it in the Guide. I will keep you posted when I have any news. Link to comment Share on other sites More sharing options...
KNAP Posted February 25, 2017 Share Posted February 25, 2017 Anyone had a reply from HMRS on this restriction? Link to comment Share on other sites More sharing options...
Peter Ruifrok Posted February 25, 2017 Author Share Posted February 25, 2017 Not yet (but I had not expected so). I will certainly post a message once I have, with the result. Link to comment Share on other sites More sharing options...
