Spireblade Posted May 15, 2017 Share Posted May 15, 2017 Is it possible to start up Railmaster Pro with a 75% screen instead of the default 100% or do I have to manually decrease it on every boot up? Cheers. Link to comment Share on other sites More sharing options...
RDS Posted May 15, 2017 Share Posted May 15, 2017 It should remember the last zoom level you were displaying. Mine certainly does, as I always view mine at 50% (I do have Pro Pack but I don't think that is a Pro Pack feature) Link to comment Share on other sites More sharing options...
96RAF Posted May 15, 2017 Share Posted May 15, 2017 Am-pack defaults to 100% regardless, but Pro-pack should remember your last custom zoom setting before shutdown. If not then I suggest reporting it to HRMS using the RM inbuilt help system.Rob Link to comment Share on other sites More sharing options...
Chrissaf Posted May 15, 2017 Share Posted May 15, 2017 Screen capture below taken from RM Manual ProPack feature list.. . Link to comment Share on other sites More sharing options...
MetmanUK Posted May 15, 2017 Share Posted May 15, 2017 If I remember correctly (I've not had time to play trains for a while) I recorded a program that set the zoom level, then run that at startup. Link to comment Share on other sites More sharing options...
RDS Posted May 15, 2017 Share Posted May 15, 2017 Just one of the many advantages of Pro Pack then, although that tip to set it in a program seems like a good workaround. Link to comment Share on other sites More sharing options...
Spireblade Posted May 16, 2017 Author Share Posted May 16, 2017 I have Pro pack and read that this is a feature. Mine certainly dosen"t automatically save the screen zoom etc and wondered if theRe was a check box that I had overlooked. I will report it to HMRS. Thanks again chaps. Link to comment Share on other sites More sharing options...
RDS Posted May 16, 2017 Share Posted May 16, 2017 There are no check boxes. I just chose the zoom required and close RM down (just by clicking the cross in the top right corner) and next time I open RM, it opens at the same zoom level. I use the classic display, just in case that makes any difference - I will check later. Link to comment Share on other sites More sharing options...
RDS Posted May 16, 2017 Share Posted May 16, 2017 Further to my post at 10:03 today, I have checked other Display modes and with every one, RM restarts at the same zoom level as when I shut it down. Link to comment Share on other sites More sharing options...
Chrissaf Posted May 16, 2017 Share Posted May 16, 2017 Spire, I take it you do get the 'ProPack' splash screen when starting up RM? to confirm that ProPack is loading. Link to comment Share on other sites More sharing options...
Spireblade Posted May 16, 2017 Author Share Posted May 16, 2017 Hi Chrissaf, all sorted now thanks. Not sure why it wouldn't work before but a bit of messing around and it now reverts to 75% once booted up, maybe I wasn't leaving it long enough. However the tab that expands the screen at the bottom goes back to "small" mode on every boot up. It's not particularly annoying as it's only a click to expand it again. Cheers Link to comment Share on other sites More sharing options...
RB51 Posted May 16, 2017 Share Posted May 16, 2017 The tab for setting the screen zoom level is top left the main track operating window. This is the one that RM should remember at start up. If you altering the zoom in a tab lower left, it sounds to me as though you are making an adjustment in the track design window. This one allows you to have a better view for track/icon placement. R- Link to comment Share on other sites More sharing options...
