skidder1 Posted June 22, 2017 Share Posted June 22, 2017 Hi all,I want to simulate a hydraulic leak at 1/48 scale, any ideas on how this could be a achieved ? I am reasonably new to the forum and couldn't find a reference to it, but apologies if this question has been asked before.Si Link to comment Share on other sites More sharing options...
Kenneth ONeill Posted June 22, 2017 Share Posted June 22, 2017 Is it a static leak or a dynamic one?Presuming it's on an aircraft, a static leak will appear, run down the side perpendicular to the ground plane, then drip from the lowest point of the line and pool below that.A dynamic leak will run roughly "straight back" subject to the airflow. See pics of Messerschmitt bf109G "G6" for illustrations of just how counter-intuitively that could make a leak flow! Link to comment Share on other sites More sharing options...
Dad Paul B Posted June 25, 2017 Share Posted June 25, 2017 One technique I have found here and in Airfix Model World is the use of oil paints. Apply dots of suitably coloured oil paint (for an oil leak Raw and Burnt Umber, not sure what colour hydraulic fluid would be). After allowing a few hours to partially dry use a cotton bud or soft brush moistened with white spirit to streak the oil paint in the direction of the leak.You can always practice on some scrap plastic to see what works. Link to comment Share on other sites More sharing options...
skidder1 Posted June 26, 2017 Author Share Posted June 26, 2017 Thanks Dad Paul B, will give that a go, starting with some research on what colour the fluid should be.Paws4thot - the model is actually a 1:48 BAR Warrior - I normally paint to the manual, however wanted to try something different having obtained some photo-etched parts, so thought of adding some weathering, but also wanted a bit more than just some mudded tracks. The end will hopefully be some kind of repair scenario diorama, will post some pictures when this finally gets completed. Si Link to comment Share on other sites More sharing options...
DavidJC Posted June 26, 2017 Share Posted June 26, 2017 Any other tips? Something I am interested in myself. Link to comment Share on other sites More sharing options...
Kenneth ONeill Posted June 26, 2017 Share Posted June 26, 2017 @skidder1 - That's relatively easy then, oil (and hydraulic fluid) will run more or less straight down from the leak point. Link to comment Share on other sites More sharing options...
