Chris Surrey Posted August 16, 2017 Share Posted August 16, 2017 @St!ngr4yI updated from the file on this Forum and have had no problems with my sound locos though none are Hornby or TTS. Link to comment Share on other sites More sharing options...
St1ngr4y Posted August 16, 2017 Share Posted August 16, 2017 Hi Chris,This corrupt file is only used when you add a new Hornby loco to your list. It doesn't affect already created locos.Ray Link to comment Share on other sites More sharing options...
WilliamDavid Posted August 16, 2017 Share Posted August 16, 2017 Interestingly, after the latest download being ok on my existing laptops, I have just received a new Linx 1020 and downloaded RM. It messed up on sound locos as previously. I redownloaded it and reinstalled and now all is now ok.Computers are bad for your health. Link to comment Share on other sites More sharing options...
BagEndJct Posted August 17, 2017 Share Posted August 17, 2017 Having let RM update itself yesterday, it will no longer read my loco CV values. It just sits there doing nothing, no warning about time it will take etc. Having closed the loco window, it eventually comes up with an error box saying it cannot read the decoder. Anyone else, please? Link to comment Share on other sites More sharing options...
BagEndJct Posted August 17, 2017 Share Posted August 17, 2017 OK, I just found the problem with reading CVs having updated to RM 1.66. I just spotted that the "Range of CVs" to read had been reset as "from 0 to 0". Change the 2nd 0 to the appropriate number and all is well. I wonder if anyone else has experienced this? At least it was a simple one to solve! I am upset that my problem with the large loco windows sticking to my mouse pointer has not been solved with this update. That's a blow. RM support are well aware of the problem. Link to comment Share on other sites More sharing options...
Georgef Posted August 18, 2017 Share Posted August 18, 2017 HiJust come across this topic and have been downloading RailMaster updates because I have no Internet on my PC running RM. I updated to 1.65 Version 1 and found that it didn't have the sound details for the new Merchant Navy R3382TTS but had the loco in the database.I found that the link I was using doesn't have anymore updates - in fact it went back to a previous version!However, I came across this topic and have managed to download version 1.66 . As I stated just stated, I won't be able to update in the usual manner, so will I be able to download the loco_en.dat file elsewhere, please?Well, I have just installed 1.66 and found that I now can't find the Merchant Navy in the database at all!!Help, please.Many thanks Link to comment Share on other sites More sharing options...
St1ngr4y Posted August 18, 2017 Share Posted August 18, 2017 I don't know if this is the cause of your problem, but in the file LOCOS.DAT, the record for R3382T may be incorrect, as it seems to have a cross-reference to R3436 in it. Maybe HRMS can investigate this.... R3382 is definitely in the func_en.dat file. Ray Link to comment Share on other sites More sharing options...
Georgef Posted August 19, 2017 Share Posted August 19, 2017 Many thanks - I'll give it another go tomorrow Link to comment Share on other sites More sharing options...
mikejj101 Posted August 22, 2017 Author Share Posted August 22, 2017 HiJust come across this topic and have been downloading RailMaster updates because I have no Internet on my PC running RM. I updated to 1.65 Version 1 and found that it didn't have the sound details for the new Merchant Navy R3382TTS but had the loco in the database. GeorgeF - I just wondered how you managed to activate RM with no Internet connection ? Link to comment Share on other sites More sharing options...
Fishmanoz Posted August 22, 2017 Share Posted August 22, 2017 You cannot activate unless you have an internet connection. And you should also update to latest 1.66 from the link to check if you still have a database problem. Link to comment Share on other sites More sharing options...
Georgef Posted August 23, 2017 Share Posted August 23, 2017 The PC it's working on did have an internet connection when I installed it and activated RM. I have since moved the PC to the shed where I am having difficulty getting the network to work.However, I managed to download 1.66 again on my laptop in the house and transfered it with the aid of a USB stick - performed the upgrade and now find that I can find the R3382TTS in the database but as Ray said it must be referencing a different model as the picture that appears is not the one in the Photos dir for R3382 - probably R3436!No sounds allocated though! Link to comment Share on other sites More sharing options...
Chrissaf Posted August 23, 2017 Share Posted August 23, 2017 George,You probably need to temporarily move the RM PC into the house so you can connect it to the Internet. That way the 1.66 installed version can silently update the out of date loco sounds file when RM is started up. This updated file is not in the current 1.66 installer download and needs to be auto updated by RM over the Internet. Link to comment Share on other sites More sharing options...
Georgef Posted August 23, 2017 Share Posted August 23, 2017 Ah OK ChrisMany thanks - I'll see what I can do - maybe get a really long ethernet cable :) or move it as a last resort :) Link to comment Share on other sites More sharing options...
Chrissaf Posted August 23, 2017 Share Posted August 23, 2017 A Category 5 UTP (Unshielded Twisted Pair) Ethernet cable terminated on RJ45 8 pin connectors (a fairly standard twisted pair Ethernet cable design) is good for 100 metres as long as it is one unbroken length i.e not 20 x 5 metre cables connected together in series by RJ45 couplers. Link to comment Share on other sites More sharing options...
St1ngr4y Posted August 24, 2017 Share Posted August 24, 2017 My layout is in the loft, but rather than use a wi-fi connection, I have wired my ethernet connection via the mains using a pair of these :-https://www.maplin.co.uk/p/devolo-dlan-550-duo-pass-through-powerline-single-socket-a83uz I have had no problems at all with it.Ray Link to comment Share on other sites More sharing options...
Georgef Posted August 25, 2017 Share Posted August 25, 2017 Hi ChrisMany thanks for the info.I am getting my son to make a 35m ethernet cable for me Link to comment Share on other sites More sharing options...
Georgef Posted August 25, 2017 Share Posted August 25, 2017 Hi RayMany thanks for your infoI have a BT Wi-Fi Home Hotspot 500 System and have not had much luck with it.The main problem being that the shed power Distribution Board is an extension off the Distribution Board in my garage. The garage power itself is an extension off the main house board! All via RCDs and safe, though.I am not really surprised that I am having problems as they recommend that both hotspot units should be on the same ring.I will wait for the cable that my son is going to make for me. Link to comment Share on other sites More sharing options...
Chrissaf Posted August 25, 2017 Share Posted August 25, 2017 George,I assume your son is familiar with Ethernet Cable pin connections, but just to be 'belt n braces' I have posted the pin connections below. For a RJ45 to RJ45 cable going from a broadband router or hub/switch to a PC he needs to use the pin out table for the 'straight through' cable..For anybody contemplating making an Ethernet cable, remember it has to be made using Category 5 (or higher) UTP cable not just any old 4 wire twisted pair (for example CW1300 specification telephone wire cable.......totally unsuitable). Crimp on RJ45 8 pin connectors are available from most electronic component suppliers..Note: the UTP cable will typically have 4 twisted pairs in it giving a total of 8 wires. Only 4 wires are needed for Ethernet. But make sure that the Tx wires are both on ONE of the twisted pairs and the Rx wires are BOTH on another twisted pair within the cable. DO NOT split the individual Tx & Rx wires across different twisted pairs within the cable. Severe crosstalk will result if you do./media/tinymce_upload/d74a9743560c6b0511ab299f1bd852b3.jpg.To be honest, it is just far easier to order a 'custom length' RJ45 cable from any of the Internet PC cable suppliers offering 'made to order' cables. The cost saving of DIY is minimal. Link to comment Share on other sites More sharing options...
mikejj101 Posted August 25, 2017 Author Share Posted August 25, 2017 Regarding my original post about 1.66 issues. How about an apology from Hornby Railmaster Support ? It appears I am NOT the only person having issues.With regard to the Internet connection issue - I see you have considered the Home Wire system offered by many manufacturers. Devolo make a great selection of options. As long as you are on the same ring main as you router it's the answer to the weak WIFI problem. http://www.devolo.co.uk/The BT devices are pretty rubbish. Link to comment Share on other sites More sharing options...
Chrissaf Posted August 25, 2017 Share Posted August 25, 2017 Supplement to my post above regarding RJ45 pin wiring..Need to know what to do with the other 4 unused wires......then see this link for what pins they should be terminated on if not simply cut off. This link also confirms the pin outs shown in my previous image..http://pinouts.ru/NetworkCables/Ethernet10BaseTStraightThru_pinout.shtml Link to comment Share on other sites More sharing options...
Georgef Posted August 28, 2017 Share Posted August 28, 2017 Many thanks for your info Chris but my son is very competent and has made the cables for me before and they have been fine.I will probably get it tomorrow, when I see him next.I'll let you know how I get on Link to comment Share on other sites More sharing options...
Georgef Posted August 28, 2017 Share Posted August 28, 2017 Hi Mikejj Many thanks but I think that the operative statement is "as long as they are on the same ring main". My router and PC are 2 hops of rings away from each other, which causes the problem with the BT Home HotSpot System.Even with a WiFi repeater, I have trouble with a WiFi signal, as the walls in the bungalow must be solid concrete! Link to comment Share on other sites More sharing options...
Georgef Posted September 17, 2017 Share Posted September 17, 2017 HiHaving been on holiday, I have just received the long Ethernet cable from my son and it worked a treat accessing the intenret just fine. However on booting RM, it said it was looking for upgrades but I could not see any difference in the data. I deleted the entry for the Merchant Navy and tried adding it again but still no sound data. I will have another go tomorrow.I've also just obtained the TTS chip for my Tornado but I may have trouble fitting it as it's the Railroad Tornado and I think that may differ from the TTS version. I will check the other topics on the forum to see if others have got around the problem.CheersGeorge Link to comment Share on other sites More sharing options...
96RAF Posted September 17, 2017 Share Posted September 17, 2017 Going back to the MN. I have Clan Line setup in RM with a few sounds in place, but after the auto-update to v1.66 I see that several of the sound functions in the right hand column are underscored. When I hover of any one it says click to edit macro. When I click on them I either get the macro (e.g. P1~F3) ) - which I never put in there - or a message saying 'you cannot set a macro for a latching (on/off) loco function'. I cannot ever remember seeing these underscores before and I certainly have not entered any such macros on the functions that are play once. Has anyone else got the problem, before I report it in.Rob Link to comment Share on other sites More sharing options...
WilliamDavid Posted September 17, 2017 Share Posted September 17, 2017 I've noticed that underscoring recently.Wondered what it was. Link to comment Share on other sites More sharing options...
