Guest Posted September 20, 2017 Share Posted September 20, 2017 Contact Hornby Customer Services https://www.hornby.com/uk-en/contact to arrange repair. Link to comment Share on other sites More sharing options...
Rog RJ Posted September 20, 2017 Share Posted September 20, 2017 Before you do anything else, disconnect the Elite from the track and power supply and test that every button and control knob moves OK and that they aren't stuck down. Link to comment Share on other sites More sharing options...
RB51 Posted September 20, 2017 Author Share Posted September 20, 2017 After a accident with elite being dropped on a hard floor all that is displayed is error cn any one help Link to comment Share on other sites More sharing options...
RB51 Posted September 20, 2017 Author Share Posted September 20, 2017 Title amended to make it searchable. R- Link to comment Share on other sites More sharing options...
pidder Posted September 21, 2017 Share Posted September 21, 2017 How old is it, how long have you had it, what is the date code stamped on the underside? Link to comment Share on other sites More sharing options...
96RAF Posted September 21, 2017 Share Posted September 21, 2017 There is a basic servicability test to try in that you Press and Hold the LOCO button and power up. Release the button when you see Hornby on screen and wait. You will get a message saying it has passed the EEPROM test or not which means the basic internal gubbins is working. From there you can then press every button on the box and expect to see a corresponding number code on screen. Once finished playing with that power down and up again per normal. Of course if the drop test has done serious internal damage it will likely be purely mechanical damage and could be as simple as a cracked PCB, which may respond to soldering repairs. Drop testing does not normally affect software or how the machine boots up unless there is mechancial damage to a chip/ its pins/pcb tracks/etc. If you want to examine the internals then how to take your Elite to bits is detailed in a web site article linked to in my signature.Rob Link to comment Share on other sites More sharing options...
Kenzie10 Posted October 13, 2017 Share Posted October 13, 2017 Thanks for all your replys i sent it back to hornby who fixed it with no information what was wrong and now can not change address on 3 LaisDcc decoders i purchased this week on programme track thanks Link to comment Share on other sites More sharing options...
96RAF Posted October 13, 2017 Share Posted October 13, 2017 I would recontact them and tell them that after they reportedly fixed it it is still broken and what the problem is.Rob Link to comment Share on other sites More sharing options...
Fishmanoz Posted October 13, 2017 Share Posted October 13, 2017 I would first check that it hasn’t been returned to you in Classic mode and, if so, change it to Standard mode as per the manual and see how it goes then. Link to comment Share on other sites More sharing options...
96RAF Posted October 14, 2017 Share Posted October 14, 2017 If Hornby updated the firmware to v1.44 during the repairs it should boot into Standard mode but worth a check.Rob Link to comment Share on other sites More sharing options...
Kenzie10 Posted October 16, 2017 Share Posted October 16, 2017 thanks it is in standard mode and will contact hornby Link to comment Share on other sites More sharing options...
Michael_A Posted October 19, 2017 Share Posted October 19, 2017 Just out of interest, how much was the repair? Link to comment Share on other sites More sharing options...
