Chrissaf Posted December 8, 2017 Share Posted December 8, 2017 A new version of RM is now available on the download link. The previous version file was 73,371,581 bytes. Today's version is 73,374,391 bytes. The release notes (extract below) indicate that the version is updated to 1.67 but oddly the file itself still reports in properties to be 1.66.1 not only that but the release notes state the RM manuals have been updated, but the front cover of the new manual still shows the Aug 2017 date (the file size is bigger though indicating that it is an updated document)..Anyway who is going to be first to install and report back findings?./media/tinymce_upload/a82eab8e90fb9171125c46e3b1ea574f.jpg. Link to comment Share on other sites More sharing options...
96RAF Posted December 8, 2017 Share Posted December 8, 2017 It will be interesting to see if the improved TTS decoder CV codes read facility is incorporated. I can't check as it will swamp my PAYG allowance with all the other updates the laptop needs.Rob Link to comment Share on other sites More sharing options...
Chrissaf Posted December 8, 2017 Share Posted December 8, 2017 Post Update:.I reported my version number discrepancy findings to HRMS via email and got this reply within a few minutes. So be aware, if you download and install this new version today, then you will probably need to do it again in a few days time if you want the updated version numbering showing:.This is correct Chris. The full 1.67 update will be released within the next few days. Regards RailMaster Support.PS - This initial 1.67 RM release, still shows 1.66 in the yellow version number box bottom right of the screen. And still shows 1.66 in the Windows Control Panel for Installed Programs. I would expect that these will show 1.67 in the next release. Link to comment Share on other sites More sharing options...
BagEndJct Posted December 8, 2017 Share Posted December 8, 2017 I'm hoping my problem with "sticky" loco windows and the Signal Settings window issue whereby the right half of the window disappears when I use it (both reported to HRMS). I will report back once the final version is available. Link to comment Share on other sites More sharing options...
96RAF Posted December 8, 2017 Share Posted December 8, 2017 BEJHRMS has said in reply to me that the sticking to mouse throttle issue is a Microsoft problem and as such they can't fix it so we are stuck with it. Maybe our PC guru AC could confirm/refute the possibility of that for us.Rob Link to comment Share on other sites More sharing options...
Chrissaf Posted December 8, 2017 Share Posted December 8, 2017 But didn't HRMS state in a previous post that they were going to re-write the slider sub routine in RM to try and fix the problem. Or is my memory failing me? Link to comment Share on other sites More sharing options...
96RAF Posted December 8, 2017 Share Posted December 8, 2017 On reflection Chris I think they did.So amend my previous to read '...can't fix it yet....stuck with it for now...'Rob Link to comment Share on other sites More sharing options...
BagEndJct Posted December 8, 2017 Share Posted December 8, 2017 BEJHRMS has said in reply to me that the sticking to mouse throttle issue is a Microsoft problem and as such they can't fix it so we are stuck with it. Maybe our PC guru AC could confirm/refute the possibility of that for us.RobAnd they said to me that no one else was getting the same problem(s) that I was, until I pointed to others that were. If it's a MS issue then it's very, very odd it doesn't happen elsewhere. I have had my laptop now for 5 years and only with RM have I ever had a problem with the cursor/pointer. Link to comment Share on other sites More sharing options...
96RAF Posted December 8, 2017 Share Posted December 8, 2017 Although not shown in the release notes I can say that if you double click in CV7 you can pull down the correct decoder which will then force the correct set of CVs to load allowing you to re-read those values. This was supposed to be in v1.66.1 Previously but as it was not advertised no one tripped over it.Rob Link to comment Share on other sites More sharing options...
St1ngr4y Posted December 11, 2017 Share Posted December 11, 2017 I suppose when the "real" version 1.67 is ready, users will be invited to download it during the Railmaster startup ? Ray Link to comment Share on other sites More sharing options...
Slornie Posted December 11, 2017 Share Posted December 11, 2017 Although not shown in the release notes I can say that if you double click in CV7 you can pull down the correct decoder which will then force the correct set of CVs to load allowing you to re-read those values. Isn't that the third bullet in the screenshot from Chris' original post? "Facility in Loco CVs editing to force any other decoder" Link to comment Share on other sites More sharing options...
96RAF Posted December 11, 2017 Share Posted December 11, 2017 Yes it is Slornie, my bad.However it behoves one working out how to do that so my explanation may be useful.Rob Link to comment Share on other sites More sharing options...
WilliamDavid Posted December 11, 2017 Share Posted December 11, 2017 I suppose when the "real" version 1.67 is ready, users will be invited to download it during the Railmaster startup ? RayDoes that ever happen? Can't recall seeing it. Link to comment Share on other sites More sharing options...
St1ngr4y Posted December 12, 2017 Share Posted December 12, 2017 It doesn't happen if the revision number changes, but if the version number changes (e.g. from 1.66 to 1.67), then, yes, Railmaster should detect this when loading, provided of course, that your pc has an internet connection. If you take a look at the file log.txt in the RM folder, you should see some entries such as these:-Checking for program updates (primary)Checking for updates available in EnglishChecking available version: 1.66.0 against current: 1.66 Ray Link to comment Share on other sites More sharing options...
WilliamDavid Posted December 12, 2017 Share Posted December 12, 2017 It is still at 1.66. Where is this 1.67 coming from?Anyone have any idea what error code 183 is? This has appeared during the latest installation. Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 12, 2017 Share Posted December 12, 2017 Google will turn up a whole universe of error 183 info. We may need AC’s help here. Link to comment Share on other sites More sharing options...
WilliamDavid Posted December 14, 2017 Share Posted December 14, 2017 Is there a problem with the RM link above? Tried it on two tablets with no joy. Link to comment Share on other sites More sharing options...
Chrissaf Posted December 14, 2017 Share Posted December 14, 2017 The download link was working this morning. But you are right, the download file is currently not there. Just try again later. Link to comment Share on other sites More sharing options...
WilliamDavid Posted December 14, 2017 Share Posted December 14, 2017 Thanks for responding so quickly, Chrissaff.I'm relieved it's not my tablets.Back on again.Still 1.66???????? Link to comment Share on other sites More sharing options...
Chrissaf Posted December 14, 2017 Share Posted December 14, 2017 The download link seems to be working again, but still downloads the same file as before. That is to say, no further update to the previous one. I will keep daily monitoring for changes as I normally do. It's still very strange that the 'release notes' clearly state 1.67, but the files internally report 1.66 Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 17, 2017 Share Posted December 17, 2017 Minor enhancements and bug fixes based on items reported on the forum... Hopefully the humble 2 aspect signal bug will also be fixed. Link to comment Share on other sites More sharing options...
WilliamDavid Posted December 17, 2017 Share Posted December 17, 2017 I have a strange issue on two of my tablets after the recent download.The bottom RH window shows 1.66 rev1, whereas my main tablet, with PRO, shows 1.66 rev 0.The system settings window now shows the loco detection wndow on both settings.I have fixed this on one tablet by downloading a previous version. Link to comment Share on other sites More sharing options...
WilliamDavid Posted December 17, 2017 Share Posted December 17, 2017 Just downloaded the link above, and it is still corrupted.Can anyone explain what's going on? Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 17, 2017 Share Posted December 17, 2017 What do you believe the corruption is WD and have you reported it to HRMS? Link to comment Share on other sites More sharing options...
WilliamDavid Posted December 17, 2017 Share Posted December 17, 2017 As I stated above. I have sent a message to support.I'm puzzled that no one else has not experienced this. Link to comment Share on other sites More sharing options...
