grumpy old man Posted January 8, 2012 Share Posted January 8, 2012 Happy new year to all I am having problems activating my points whilst on Railmaster.I have read previous comments and followed all advice without success.The History is, I am using an Elite controller on standard mode V1.4 which controls all my points Ok yet when on Railmaster they will not work.I have 4 x R8216 decoders operating 13 points as numbered below:Controller 1 = 61.62.63.64Controller 2 = 69.70.71.72Controller 3 = 73.74.75.76Controller 4 = 77I set up a test point on Railmaster & numbered it 64 but no success.Have I ommitted to carry out anything else? Any assistance would be much appreciated but please bear in mind I am a novice and still but willing to learn.Thanx in advanceDon RAny further assistance would be greatly appreciated Link to comment Share on other sites More sharing options...
stevecamden Posted January 8, 2012 Share Posted January 8, 2012 I take it they work on the Elite alone? ( without Railmaster)Was there some reason why the numbering is 61 - 64 ( Is this something to do with the Select controller?)I have only the R8247 point controllers and have numbered mine.Controller 1 = 1.2.3.4Controller 2 = 5.6.7.8So, when defining a point in Railmaster, I just set Controller A port 1 - 8 for each point.Steve Link to comment Share on other sites More sharing options...
grumpy old man Posted January 9, 2012 Author Share Posted January 9, 2012 stevecamden said:I take it they work on the Elite alone? ( without Railmaster)Was there some reason why the numbering is 61 - 64 ( Is this something to do with the Select controller?)I have only the R8247 point controllers and have numbered mine.Controller 1 = 1.2.3.4Controller 2 = 5.6.7.8So, when defining a point in Railmaster, I just set Controller A port 1 - 8 for each point.Steve Link to comment Share on other sites More sharing options...
grumpy old man Posted January 9, 2012 Author Share Posted January 9, 2012 Hi SteveYes I recall setting the points with my select cos my elite was faulty at the time this has now been rectified by Hornby who replaced it FoC.Can I re-number the points as you have shown above ??Thanx for your replyDon R Link to comment Share on other sites More sharing options...
stevecamden Posted January 9, 2012 Share Posted January 9, 2012 Hi DonI have no direct experience of these decoders as I always have used the R8247 one, but I can't see why not. If I remember correctly the reason why the numbering had to start at 61 was because of the Select controller. ( But I may be wrong)Well it can't do any harm to try it! have a go and see if the Elite flashes a bit when you reset the decoder.A bit of flashing and clicking is always a good sign - just make sure the connections to the programming track are ok. If you have a meter you should see it power when activated by the Elite.Steve Link to comment Share on other sites More sharing options...
SailorSam Posted January 10, 2012 Share Posted January 10, 2012 Hi Don, I would be interested in seeing if you are successfull in programming your point decoders with your Elite V1.4. I have just recieved two of the R8247 point decoders, i set one up as No.1 (ports 1-4) and connected 4 points to it and got that all going ok. Later i managed to finally update my Elite to V1.4 (was V1.3) and tried to set up my second R8247. All i got was about 15 red flashes on the Elite which indicates the decoder has not accepted or has not been given the correct information. If successful you should get 5-7 red flashes if not you will get more than 8!!. In desperstion i reflashed my Elite back to V1.3 and was successfull in setting up the second decoder and connecting another 4 points to it. I have an XP pro pc with a touch screen running Railmaster V1.3 and it all seems to work as it should. Link to comment Share on other sites More sharing options...
Montywb Posted January 10, 2012 Share Posted January 10, 2012 I also, seem to have a problem with a couple of R8216 decoders. They appear not to want to work under v1.4 and re-programming appears to be successful with regard to the number of flashes but isn't, either when controlled by Railmaster or the Elite. Anyone else having this problem? Link to comment Share on other sites More sharing options...
stevecamden Posted January 10, 2012 Share Posted January 10, 2012 I wonder if the Elite has to be reset after the update. Sort of 'blow any residual cobwebs away' - Have to tried that?Steve Link to comment Share on other sites More sharing options...
Montywb Posted January 10, 2012 Share Posted January 10, 2012 No, I haven't Steve, I'll try it and report back.Monty Link to comment Share on other sites More sharing options...
Montywb Posted January 10, 2012 Share Posted January 10, 2012 Unfortunately a reset doesn't resolve the situation.Monty Link to comment Share on other sites More sharing options...
Valderrama Posted January 10, 2012 Share Posted January 10, 2012 Hi AllJust a reminder that Point Control direct from the Elite on V1.4 is by alternate pressing of Controllers 1 and 2 and not continual pressing of one controller.I got caught out by this for a while.Regardsderrick Link to comment Share on other sites More sharing options...
stevecamden Posted January 10, 2012 Share Posted January 10, 2012 Looks like a job for Hornby CCSteve Link to comment Share on other sites More sharing options...
Montywb Posted January 11, 2012 Share Posted January 11, 2012 Oddly enough, today, everything is working just as it should. Mysterious.Monty Link to comment Share on other sites More sharing options...
arrow6 Posted February 19, 2012 Share Posted February 19, 2012 Dear All,I am really frustrated trying to get my 8216 Point Controllers working with Elite running v1.3.I have set up a test track running a single Peco Point Motor. The 8216 will programme correctly but when trying to activate the point, nothing happens. I have set the point address to read 1I am not using Railmaster yet just direct from the Elite unit with a single 8216 unit.Appreciate any advise from anyone out there.ThanksAndrew Link to comment Share on other sites More sharing options...
grumpy old man Posted February 22, 2012 Author Share Posted February 22, 2012 HiI am operarting 5 x R8216 decoders Ok (after a few problems).First download the V1.4 to your Elite then ensure you are on Standard mode.The R8216 points code from 61 in groups of 4 61 will auomatically code 61-64.Hope this helpsDon R Link to comment Share on other sites More sharing options...
Dylans_Grandad Posted February 23, 2012 Share Posted February 23, 2012 I would like to add that I am also operating a 'conversion' layout originally operated with the Select. I have 3 point decoders operating from 61 to 71. However I have 2 point motors connected to 3 of the outputs (61,70 and 71)such that they are always required to operate together. This has worked without any problems with the Select. On purchasing an Elite and connecting this up I found that I had to reprogramme the decoders from the Elite which was straightforward as I wired them originally through an additional home made control box and each decoder was connected via phono plugs. I kept the same numbering 61 to 71 as I have little white gradient posts next to each bearing the point number. When Railmaster was installed and the layout called up at startup the system went round checking all the points as it said it would. From that screen layout the points operate correctly by clicking on the red/green 'buttons' and the direction (blue) changes as it should. I have a programme working very successfully. The only problem that occured was when the Select was attached to the Elite. Arbitory point motors fired when trying to select a point. Don't need to but thought I'd try it. Select can call up locos and run them on branch lines etc even with a programme running. I find it great and so does my 10 year old grandson. (He's quicker at picking it all up than me!) Good luck to you all. Stick with it.JohnS Link to comment Share on other sites More sharing options...
96RAF Posted March 2, 2012 Share Posted March 2, 2012 HiRemember that when addressing R8247 point and accessory decoders with the Elite you first need to set CV513 in accordance with the instructions (somewhere on this site, which I can't put my finger on, or should that be mouse). This sets the box into group addressing mode, which means that if you give this box address 1, it allocates points addresses 1, 2, 3 & 4 automatically.Do the same again for box 2 as address 2 and it allocates points adddresses 5 to 8, and so on for more boxes in groups of 4 points. Maybe HCC could post the R8247 instructions as a sticky on this forum please.Robbie Link to comment Share on other sites More sharing options...
Gregd99 Posted March 2, 2012 Share Posted March 2, 2012 8247 instructions are at https://www.hornby.com/filelibrary/download/?FileID=175 Link to comment Share on other sites More sharing options...
96RAF Posted March 4, 2012 Share Posted March 4, 2012 SteveNo reason you should have to reset the Elite after updating it. All you will achieve is losing any loco names, favourite lists, etc.Re acc decoder addressing - follow the instructions, by setting cv513 this puts the decoder into Group Addressing mode, then address 1 will set points 1 to 4, address 2 will set points 5 to 8, etc.Robbie Link to comment Share on other sites More sharing options...
96RAF Posted March 4, 2012 Share Posted March 4, 2012 Hi Moderator - could you please delete the double post - no idea how that happened.Robbie Link to comment Share on other sites More sharing options...
