ray-s Posted February 15, 2018 Share Posted February 15, 2018 can you fit a decoder to a hornby R1080 Link to comment Share on other sites More sharing options...
DEREK123 Posted February 15, 2018 Share Posted February 15, 2018 tHiWhat is an R1080 ? I could not track a Spec sheet down. Is it a Virgin 125 ?Derek Link to comment Share on other sites More sharing options...
2e0dtoeric Posted February 15, 2018 Share Posted February 15, 2018 Hattons special - http://www.hattons.co.uk/17568/Hornby_R1080_Virgin_Cross_Country_HST_complete_train_set/StockDetail.aspxsnipped - Hornby R1080 OO Gauge (1:76 Scale) "Virgin Cross Country HST" complete train set DCC suitability unknown so you'd probably have to hard-wire it. Link to comment Share on other sites More sharing options...
Howbi Posted February 15, 2018 Share Posted February 15, 2018 Yes you can fit a decoder into this 125 style loco but you will have to solder it to the wiring from the pickups and the motor.......the best way would be to install an 8 pin socket which would also enable you to fit front and rear lights.........depending on your soldering skills......with the socket in place it is then easier to change the decoder in the future if needed.........HB Link to comment Share on other sites More sharing options...
ray-s Posted February 15, 2018 Author Share Posted February 15, 2018 thanks i will give fitting the decoder a try Link to comment Share on other sites More sharing options...
Michael_A Posted February 19, 2018 Share Posted February 19, 2018 On a side note, Hattons own decoders plug into a harness, so you don't have to fit the 8 pin socket to replace the decoder.... Link to comment Share on other sites More sharing options...
96RAF Posted February 19, 2018 Share Posted February 19, 2018 There is a guide to installing a decoder in a HST125 in the DCC+ section of this site.Rob Link to comment Share on other sites More sharing options...
