pidder Posted April 22, 2018 Share Posted April 22, 2018 I would like to add TTS to my Vale of York diesel, but this class 59 appears not to have a specific decoder. Could someone please advise as to an approprite decoder and perhaps a suitable sugar cube speaker? Thanks. Link to comment Share on other sites More sharing options...
Howbi Posted April 22, 2018 Share Posted April 22, 2018 The class 59 locomotive was fitted with an E.M.D. 16-645 turbo diesel.......the closest TTS decoder at present might be the Class 40, only on the basis that the original is also fitted with a Vee 16 turbo diesel so probably a similar sound......this decoder comes with a rectangular speaker which would be worth trying before you buy an alternative..........the size of 'sugar cube' speaker you will have to determine when you take the top off.......for a good choice of speakers have a look here..... http://www.youchoos.co.uk/Index-Shop.php?L1=Speakers ..........HB Link to comment Share on other sites More sharing options...
ellocoloco Posted April 22, 2018 Share Posted April 22, 2018 I would suggest using the Class 66 TTS decoder - the 710-12 in the 66 and 645-16 in the 59 are two stroke units with a distinct sound and are all descended from the EMD 567 series. The Class 40 had a four stroke EE 16SVT, which I will admit to never hearing, should be quite different to the EMD sound from the 59. Link to comment Share on other sites More sharing options...
pidder Posted April 22, 2018 Author Share Posted April 22, 2018 Hello Both, thanks for your replies. Think I'll try the Class 66 decoder, I'm not too fussy but just wanted advice as to what would sound suitable, I have no TTS diesels at present. I'll also try the supplied speaker at first. Thanks for your help. Link to comment Share on other sites More sharing options...
pidder Posted April 23, 2018 Author Share Posted April 23, 2018 TTS decoder for class 66 doesn;t seem to be available till later in the year, perhaps. I'm going to try with my class 67 for which a decoder is available. Link to comment Share on other sites More sharing options...
96RAF Posted April 23, 2018 Share Posted April 23, 2018 Class 67 has distinctive startup sequence with a warning horn and it whines. Link to comment Share on other sites More sharing options...
richard_croft Posted April 23, 2018 Share Posted April 23, 2018 If you aren’t Bothered about it being 100% then the 66 will be fine, if you watch a video of a class 66 and. 59 on YouTube you will see that they sound similar, if you watch a 66 and a 67 you will struggle to tell the difference at all as they both use the same engine.im not sure why you would want a sugar cube in a class 59, sugarcube speakers are useful for when there is limited space but a Hornby 59 has loads of space available. I’d suggest a speaker something like this: http://roads-and-rails.co.uk/store/p74/Square_Megabass_Speaker.htmlbut even the standard speaker properly sealed would be better than a sugarcubethe 67 has space for a speaker in the tanks, again it can be improved by upgrading the speaker, this one is a direct fit: http://roads-and-rails.co.uk/store/p77/Bass_Enhanced_Speaker_20x40mm.htmlRichard Link to comment Share on other sites More sharing options...
pidder Posted April 24, 2018 Author Share Posted April 24, 2018 Thanks for both replies, a 66 TTS doesn't seem to be available till later in the year, that's why I decided to try my class 67 - 67018 RAPID, which, incidentally, is on youtube...showing starting up with the start horn...also useful gen re the various speakers available... Link to comment Share on other sites More sharing options...
