Poppa Wheely Posted April 24, 2018 Share Posted April 24, 2018 I need tires for the new Ford Mach IV's and Ford Cortinas. The Mach IV tends to lose it in high speed turns. I tried sand paper but its not good enough. And the cortina behaves poorly in turns as well. Any thoughts? Link to comment Share on other sites More sharing options...
woodcote Posted April 24, 2018 Share Posted April 24, 2018 Paul Gage in Canada produces very nice urethane tyres as replacements for almost all Scalextric wheels. Not sure he has any for the Ford MkIV yet. Before replacing the tyres, I think it's worth identifying exactly why the cars are deslotting. Could be the back is stepping out (= oversteer / car is "loose") or it's the guide that is lifting (= understeer / car is "tight"). Oversteer is usually improved with more grippy rear tyres. Replacement tyres are one solution or softening the existing tyres with a little oil brushed on to the surface and soaked up. If you're running with magnets, more magnet will help. Understeer can be caused by the guide not getting deep enough into the slot. Grinding down the front tyres will help, as may adding a little weight inside the chassis at the front. I aim for the front tyres to be just touching the track with the guide fully in the slot. Another issue with the Cortina is that it can't be expected to be as quick through the turns as more sleek sports cars etc. The car has a high centre of gravity, a narrow track and thin tyres. That makes it great fun to drive (in my opinion) but best to race against similar cars. Link to comment Share on other sites More sharing options...
BobbyEAZ Posted April 24, 2018 Share Posted April 24, 2018 SUPER TIRES are on all my Scalextric and Slot.it cars. They are made in the U.S.A. Great prip and they last forever. Link to comment Share on other sites More sharing options...
Poppa Wheely Posted April 24, 2018 Author Share Posted April 24, 2018 Cant add weight or extra magnets. Not allowed where I come from. Only modifications are tires and digital chip. However, I did some work on the cortina just to see what would happen. I ended up trying several things and they didnt work. Extra weight on the chasis, no good. Cant add magnet in chassis because its the one that lays under the engine and it cant get any bigger without impeeding the motor. I eventually setteled with super glueing a piece of a magnet on the outside of the chasis right behind the rear axle. It stays on the track better but you have to apply more throtle which changes the whole behavior of the car and it still isnt very competitive. I realy like the look and era of the car. Bathurst 64 and all or even against the 70 ford escort(which runs circles aroun it). I once ordered tires from Canada and they never came. I ended up getting a refund and just moved on. However, they were the only place that advertised having tires for the cortina. They are so small and thin. Its hard to believe this car actually competed and won in real life being so aerodynamicly challenged. Link to comment Share on other sites More sharing options...
gorp Posted April 25, 2018 Share Posted April 25, 2018 magnet behind rear axle will lift front end , in front it will add usefull downforcewhile found less is better with digitalbut believe mk4 problem is that bike on and off motorsome people swear by smoother slower versions of it but have never tried since avoid slots now requiring more than tire replacement if Poppa is in new world, Gage is on ebay too and do recommend him if you want urethanes interesting comments on over and understeer Woodcotejust was reading a 40 year old slot book and the solutions then was exact oppositeguess some theories change in time Link to comment Share on other sites More sharing options...
Andy P. Posted April 25, 2018 Share Posted April 25, 2018 interesting comments on over and understeer Woodcotejust was reading a 40 year old slot book and the solutions then was exact oppositeguess some theories change in timeThere are quite a few factors to consider such as what type of track they are racing on, what type of magnets (if any), the controllers, motors, braking etc and of course the cars themselves.A lot about car handling is like religion.. everyone thinks they get it right... Link to comment Share on other sites More sharing options...
Lilyvick Posted December 27, 2018 Share Posted December 27, 2018 The best way to make up mind is to compare between some options. I recently was surfing the internet about tires too and found an interesting option here. I think it's time to switch tires now as I am having a Dodge RAM. Link to comment Share on other sites More sharing options...
Steviebabes Posted December 27, 2018 Share Posted December 27, 2018 Any suggestions which tyres I need for the Micro Scalextric Grand Prix cars - Jordan and McLaren.Will new tyres stay on? These ones keep spinning off! Link to comment Share on other sites More sharing options...
woodcote Posted December 27, 2018 Share Posted December 27, 2018 Hi Steviebabes - welcome to the forum. If you can find new Micro Scalextric tyres, yes they will stay on. Alternative suggestions - and other Micro Scalextric tips - can be found on this thread: https://www.scalextric.com/uk-en/forum/tips-for-getting-the-most-out-of-micro-scalextric/ Link to comment Share on other sites More sharing options...
marcC Posted December 27, 2018 Share Posted December 27, 2018 Sounds like you are running on plastic digital track. I have had great success with silicone tires. I run on scalextric digital plastic track and I buy my tires either locally or from quick slicks. I have used Paul G's urathane tires with some success as well. Just my opinion, but I would go silicone with the front tire advice from Woodcote.Marc Link to comment Share on other sites More sharing options...
