chris_ansell Posted April 27, 2018 Share Posted April 27, 2018 Cladd 47tts loco. How do you remove the body Link to comment Share on other sites More sharing options...
Going Spare Posted April 27, 2018 Share Posted April 27, 2018 If my memory serves me correctly, the Lima body & chassis frame are used so the body is separated from the chassis by pulling out the four buffers and then releasing the horizontal lugs on the chassis frame from the recesses in the body at the bottom of each cab door by carefuly sliding a thin blunt blade vertically between the bottom of the body sides and the chassis frame within.GS Link to comment Share on other sites More sharing options...
Howbi Posted April 27, 2018 Share Posted April 27, 2018 Carefully pull the buffers out then run a thumbnail or thin strips of cut up credit card along the edge of the body moulding.......the body is clipped onto 3 lugs each side so as you slide along each side you release the lugs.........HB Link to comment Share on other sites More sharing options...
WilliamDavid Posted April 27, 2018 Share Posted April 27, 2018 I have found that guitar plectrums are ideal for sliding between the body and chassis. Link to comment Share on other sites More sharing options...
