Elliot1982 Posted May 19, 2018 Share Posted May 19, 2018 Hi So my bachmann class 47 has arrived. Already have the TTS ready with the dcc concepts adaptorThis clearly isn't going to work has its too tall now. What adaptor do I need? Link to comment Share on other sites More sharing options...
Howbi Posted May 19, 2018 Share Posted May 19, 2018 I recall reading recently that in a similar case the member had cut off the eight pin plug from the TTS and soldered the bare wires into the 8 pin socket of the adapter. The only other solution is to buy a sound decoder with 21 pins but that will be much more expensive. So no easy solution I'm afraid..........HB Link to comment Share on other sites More sharing options...
SteveM6 Posted May 19, 2018 Share Posted May 19, 2018 Yes HB, I did. Link to comment Share on other sites More sharing options...
96RAF Posted May 19, 2018 Share Posted May 19, 2018 Loads of advice on RM Web forums about TTS and 21 pin adapters and height problems.Rob Link to comment Share on other sites More sharing options...
WilliamDavid Posted May 19, 2018 Share Posted May 19, 2018 https://www.ebay.co.uk/itm/21-Pin-DCC-Adaptor-To-Fit-TTS-Sound-Decoder-To-21-Pin-Models-Class-47-37-20-66/263670696262?hash=item3d63ff8946:g:BGYAAOSwNhpa1vkb This claims to solve the issue. Link to comment Share on other sites More sharing options...
Howbi Posted May 19, 2018 Share Posted May 19, 2018 I'd like to see photographic evidence that the Laisdcc adapter solves the height issue.......the socket still has to be deep enough to house the 8 pins of the plug so the height stays the same...........HB Link to comment Share on other sites More sharing options...
SteveM6 Posted May 19, 2018 Share Posted May 19, 2018 That ain’t gonna do it - still too high.As HB said it’s the length of the Hornby pins that are the limiting factor . Link to comment Share on other sites More sharing options...
Elliot1982 Posted May 20, 2018 Author Share Posted May 20, 2018 I'd like to see photographic evidence that the Laisdcc adapter solves the height issue.......the socket still has to be deep enough to house the 8 pins of the plug so the height stays the same...........HBVia a Facebook group I've been offered the same advice for the adoptor, he said its worked on his 47 Link to comment Share on other sites More sharing options...
96RAF Posted May 20, 2018 Share Posted May 20, 2018 Are we reinventing the wheel here...same players involved and same answers coiming out. https://www.hornby.com/uk-en/forum/post/view/topic_id/22870/?p=1 ....in particular the last post on page 2. I know the other thread is a Baccy Class 37 but I doubt there is that much difference in the chassis.Rob Link to comment Share on other sites More sharing options...
WilliamDavid Posted May 20, 2018 Share Posted May 20, 2018 This works. Link to comment Share on other sites More sharing options...
SteveM6 Posted May 21, 2018 Share Posted May 21, 2018 Those breakout adapters look useful. Fundamentally the same as HB’s suggestion and I will have to get some for the spares box when they are back in stock. Link to comment Share on other sites More sharing options...
