Ard Lochan Posted July 13, 2018 Share Posted July 13, 2018 Can someone reccomend a small DCC decoder for this, Direct fit. I have tried a Hattons and a Lais but both are too wide so I can`t get the body back on. I have also tried a DCC concepts decoder but as it has a harness, same problem. Regards, Ard Link to comment Share on other sites More sharing options...
WilliamDavid Posted July 13, 2018 Share Posted July 13, 2018 Will the decoder not fit in the smokebox under the chimney? Link to comment Share on other sites More sharing options...
Fishmanoz Posted July 13, 2018 Share Posted July 13, 2018 This sounds most unusual. I cannot remember anyone reporting previously not being able to fit a decoder in a large steam loco such as this one. Link to comment Share on other sites More sharing options...
96RAF Posted July 14, 2018 Share Posted July 14, 2018 There are several FS decoder installations herehttps://www.hornby.com/uk-en/hornby-dcc/decoder-installation-guidesRob Link to comment Share on other sites More sharing options...
Ard Lochan Posted July 14, 2018 Author Share Posted July 14, 2018 It is not that I don`t know how to do it, The two direct fit I have are too wide and the wired chips wires are far too long, also the body is a very tight fit when replacing on the chassis. I have five other loco drive scotsmans and never had a problem with fitting chips. What I am going to try is this: Unscrew the socket and put it at an angle so that the sides of the body miss the edges of the chip and insulate, Regards, Ard Link to comment Share on other sites More sharing options...
Ard Lochan Posted July 17, 2018 Author Share Posted July 17, 2018 Fixed, Took the smokebox door of, decoder hanging out of the front, refitted the body and door, all good. Link to comment Share on other sites More sharing options...
