Forum-1211528 Posted July 23, 2018 Share Posted July 23, 2018 I have verious DCC fitted locos running on my layout but they are steam and diesel locos then i have verious Electic locos running under live analogue Triang overhead is it safe and fine to use these together as the two systems are separately powered?? 🤔 Link to comment Share on other sites More sharing options...
Howbi Posted July 23, 2018 Share Posted July 23, 2018 You cannot connect 2 controllers to the same track, especially DCC and analogue, fire and brimstone will result........HB Link to comment Share on other sites More sharing options...
Chrissaf Posted July 23, 2018 Share Posted July 23, 2018 I should imagine that live overhead still uses the rails as the return path, thus there is no electrical separation between the two systems. Link to comment Share on other sites More sharing options...
96RAF Posted July 23, 2018 Share Posted July 23, 2018 The live overhead will use both rails as a return path, so just putting an overhead loco on a DCC track will generate a dead short......and as HB said two ‘odd’ controllers on the same track rig will likely damage one or both controllers and anything standing on track. Rob Link to comment Share on other sites More sharing options...
Fishmanoz Posted July 23, 2018 Share Posted July 23, 2018 Just in case there is anything unclear in HB’s, Chris’s and Rob’s replies - no, you cannot run these locos simultaneously on the same track under any circumstances whatsoever! Link to comment Share on other sites More sharing options...
