Schuie52 Posted August 22, 2018 Share Posted August 22, 2018 Hi I am having problems with this shunter I have fitted the decoder the loco works then slows down and stops the controller shows E5 which I presume means overload, the decoder gets quite hot, ican reset and the problem reoccurs I suspect the problem is with the motor can any one suggest where I can get the motor fully serviced I did use a gentleman who rewound my armatue and serviced the motor completely for a triang Pullman loco but I cannot find his detailsany help would be appreciated schuie Link to comment Share on other sites More sharing options...
Rog RJ Posted August 22, 2018 Share Posted August 22, 2018 E5 means Emergency Stop. Are you using the emergency stop button? Link to comment Share on other sites More sharing options...
Howbi Posted August 22, 2018 Share Posted August 22, 2018 On my Elite controller, a short or overload shows on screen the word 'ERROR'.........when the Emergency Stop button is pressed the screen shows 'E. STOP'........there are no error codes listed in the manual.......HB Link to comment Share on other sites More sharing options...
Chrissaf Posted August 22, 2018 Share Posted August 22, 2018 ...can anyone suggest where I can get the motor fully serviced....http://www.scalespeed.co.uk/ Link to comment Share on other sites More sharing options...
96RAF Posted August 22, 2018 Share Posted August 22, 2018 E5 is a Select controller error code and does indeed indicate Emergency Stop, as Rog says a manual button press event.Rob Link to comment Share on other sites More sharing options...
