koo9 Posted January 21, 2012 Share Posted January 21, 2012 I have just opened a new decoder with a plug-in connection. One wire seems to be a fly-lead (purple/ mauve)and there is a vacant pin in the plug. It is as if the wire was missed off in the soldering process. I can't find any reference to it can anyone help please? Link to comment Share on other sites More sharing options...
Gregd99 Posted January 22, 2012 Share Posted January 22, 2012 the flying purple lead is for an extra function. it is not meant to be connected to the plug. search for purple in https://www.hornby.com/filelibrary/download/?FileID=137 Link to comment Share on other sites More sharing options...
koo9 Posted January 22, 2012 Author Share Posted January 22, 2012 Thank you, got it. David Link to comment Share on other sites More sharing options...
koo9 Posted January 22, 2012 Author Share Posted January 22, 2012 Having re-read the extensive, multi-language booklet supplied with it, there is no mention of it in there. An oversight by Hornby it seems. David Link to comment Share on other sites More sharing options...
poliss Posted January 22, 2012 Share Posted January 22, 2012 Yes, but those instructions are for the standard R8249 decoder. Koo9 says he has the R8245 Sapphire, which is a 21 pin decoder. Not having seen the decoder myself. I can't tell if the violet lead should be connected or loose. Link to comment Share on other sites More sharing options...
96RAF Posted January 22, 2012 Share Posted January 22, 2012 HiThese are the standard wire colours:Red – Right hand track contact Black – Left hand track contact Orange – Right hand motor contact Grey – Left hand motor contact White – Function output A (Front headlight, f0) Yellow – Function output B (Rear headlight, f0) Blue – Function positive common Green – Function output C (normally controlled by f1) Purple – Function output D (normally controlled by f2)Green and purple may not be present if a decoder is less than 4-function. Looking at a new Sapphire the purple wire is connected at the detachable 21 pin adaptor end and free at the 8 pin plug end.All other colours are connected at both ends. My 8-pin plug has no spare pins - all 8 are wired as above.Rob Link to comment Share on other sites More sharing options...
Gregd99 Posted January 23, 2012 Share Posted January 23, 2012 agreed that the info was for the 8245. the purple lead is always flying as far as I know. Link to comment Share on other sites More sharing options...
