Steamy1957 Posted September 8, 2018 Share Posted September 8, 2018 HiI want to fit some of my Battle Of Britain's/ West Country Locos with tts or normal decoders most of my locos have the new plug into the tender I have heard you have to be careful with the tender steps and handles when opening the tenders as they are attached and it is not straight forward any help would be welcome Regards Link to comment Share on other sites More sharing options...
walkingthedog Posted September 8, 2018 Share Posted September 8, 2018 The service sheet that came with the locos should explain what needs to be done. Do you have the loco R numbers? Link to comment Share on other sites More sharing options...
Steamy1957 Posted September 8, 2018 Author Share Posted September 8, 2018 Hornby r3468 603 squadron and the new royal observation corps hornby r3618 I think thanks Link to comment Share on other sites More sharing options...
Fishmanoz Posted September 9, 2018 Share Posted September 9, 2018 The first of those R numbers comes up DCC fitted, the second DCC Ready, both loco drive. Is yours not DCC fitted already I suggest you you don’t need to open the tender, just the loco and fit the deoder. If TTS, use a sugar cube speaker and mount in the loco too. Unless of course these are designed for TTS with decoder and speaker in the tender but I can’t see any indication that is the case. Link to comment Share on other sites More sharing options...
Steamy1957 Posted September 10, 2018 Author Share Posted September 10, 2018 The first of those R numbers comes up DCC fitted, the second DCC Ready, both loco drive. Is yours not DCC fitted already I suggest you you don’t need to open the tender, just the loco and fit the deoder. If TTS, use a sugar cube speaker and mount in the loco too. Unless of course these are designed for TTS with decoder and speaker in the tender but I can’t see any indication that is the case. Link to comment Share on other sites More sharing options...
Steamy1957 Posted September 10, 2018 Author Share Posted September 10, 2018 HiBoth the arms locos have decoders to be fitted in the tender neither is dcc fitted Regards Link to comment Share on other sites More sharing options...
96RAF Posted September 10, 2018 Share Posted September 10, 2018 In the downloads area for Maintenance Sheets there are two variants for these locos, one is not DCC ready and the other has a socket in the loco.There may be a later one that has the socket in the tender and also sound ready. If anyone has this sheet then please scan it and post on theforums. Rob Link to comment Share on other sites More sharing options...
new lad on block Posted September 11, 2018 Share Posted September 11, 2018 Hi Steamy1957,Photos of the maintenance sheets which I have for my locos. 1st. is R3468 other is R3618.More or less same except later one mentions removing Handbrake.If wanting the earlier sheets please advise and will photo.Only photographed/media/tinymce_upload/302d72760a53717677e18345f7121f20.JPG/media/tinymce_upload/abcdfbcd92754a66136c9b5503dee5c5.JPG part refering to tender. Link to comment Share on other sites More sharing options...
96RAF Posted September 11, 2018 Share Posted September 11, 2018 That arrangement looks as if it was lifted from the old MN 21-pin full fat sound loco paperwork.Rob Link to comment Share on other sites More sharing options...
Steamy1957 Posted September 11, 2018 Author Share Posted September 11, 2018 Thanks for all the info should be fine to do now I had heard you have to move the break as confirmed by your good self many thanks Link to comment Share on other sites More sharing options...
new lad on block Posted September 11, 2018 Share Posted September 11, 2018 Hi RAF96,Checked, and the paperwork is also the same for the Rebuilt WC, R2997XS & R3160XS.The earlier ones with digital sound, factory fitted. Link to comment Share on other sites More sharing options...
