Throppers Posted September 29, 2018 Share Posted September 29, 2018 Hi all,My first TTS decoder arrived in the post today and I plugged it in to test it. The decoder seems to cause very jumpy movement especially at low speed. I have testing the same loco on the same bit o track and rolling road with a different decoder and it is perfectly smooth. The wheels and track were also cleaned yesterday so it's not a contact issue. Any thoughts from anyone? I am wondering if it's simply faulty but thought I'd see if there are any suggestions before I return it.Video of jumpy running with TTS decoder fitted:https://www.youtube.com/watch?v=ZrwLeIWd7WwVideo of smooth running with Hattons decoder fitted on same loco and same bit of trackhttps://www.youtube.com/watch?v=XWzu0zjdAsA&feature=youtu.beThanks. Link to comment Share on other sites More sharing options...
96RAF Posted September 29, 2018 Share Posted September 29, 2018 You need to fiddle with TTS CVs, try setting CV150 to value 1 for a start.Then you can refine the motor response by adjusting the P & I values for the better of the 2 algorithms.Rob Link to comment Share on other sites More sharing options...
2e0dtoeric Posted September 29, 2018 Share Posted September 29, 2018 RAF is assuming the poster has an Elite or similar, and not a Select, in which case he cannot tweak cv's! Link to comment Share on other sites More sharing options...
Howbi Posted September 29, 2018 Share Posted September 29, 2018 From Throppers posts on the MRF he has equipment capable of changing all CVs.and from my experience, changing CV150 to 1 significantly improves the smooth running on the TTS decoder........HB Link to comment Share on other sites More sharing options...
Throppers Posted September 29, 2018 Author Share Posted September 29, 2018 RAF96 thank you, that has resolved it. Link to comment Share on other sites More sharing options...
96RAF Posted September 30, 2018 Share Posted September 30, 2018 RAF96 thank you, that has resolved it. Wish we had a Tick or Thumbs up button.Rob Link to comment Share on other sites More sharing options...
Gwdriver16 Posted September 30, 2018 Share Posted September 30, 2018 Take a look at my thread, on this forum,'Getting smooth running from tts decoders'see if that helps.Cheers, Rich. Link to comment Share on other sites More sharing options...
