81F Posted October 6, 2018 Share Posted October 6, 2018 Following on from my queries in the remotoring thread, can CV5 (max voltage be altered on any of the Hornby Chips? Sadly I have lost my instructions and I do not want to play with any of the CVs on my Hornby chipped locos as I have just got them running nicely. If not can anyone suggest an inexpensive alternative which can have CV 5 reduced. Link to comment Share on other sites More sharing options...
96RAF Posted October 6, 2018 Share Posted October 6, 2018 Zimohttp://www.zimo.at/web2010/products/lokdecoder_EN.htmExpand the all decoder features bit which shows all decoders support 3-point speed curves.Rob Link to comment Share on other sites More sharing options...
Rog RJ Posted October 6, 2018 Share Posted October 6, 2018 CV5 can be altered on the Sapphire decoders but not on the basic R8249 or TTS decoders.Lenz Standard decoders are very good value for money. Link to comment Share on other sites More sharing options...
Flashbang Posted October 6, 2018 Share Posted October 6, 2018 HiAs Rog has stated not adjustable on the basic Hornby decoder.If you do obtain a better decoder and can adjust CV5 then you need also to ideally adjust CV6 too. CV6 needs to be between 1/3 to a maximum of 1/2 the value of what is set in CV5.e.g. If CV5 is set to 180, CV6 needs to be around 60 to a maximum of 90. Link to comment Share on other sites More sharing options...
81F Posted October 6, 2018 Author Share Posted October 6, 2018 Thanks for all the help, I'll now go looking for a suitable decoder. Link to comment Share on other sites More sharing options...
Howbi Posted October 6, 2018 Share Posted October 6, 2018 Hattons 8 pin decoder £15, has CV5 & CV6 fully adjustable..........HB Link to comment Share on other sites More sharing options...
TrainDriverJ Posted October 6, 2018 Share Posted October 6, 2018 Hattons do have a warning that their decoders may not work with Hornby controllers. Link to comment Share on other sites More sharing options...
Howbi Posted October 6, 2018 Share Posted October 6, 2018 I have found that they work as well as others with my Hornby Elite..........HB Link to comment Share on other sites More sharing options...
pd91223 Posted October 6, 2018 Share Posted October 6, 2018 I had problems with a Hatton with my RailMaster/Elink and have had to swap it out. I replaced it with a Gaugemaster DCC29, which works fine. Link to comment Share on other sites More sharing options...
