Johnbw Posted January 5, 2019 Share Posted January 5, 2019 I am trying to fit the Digital Sound decoder R8109 to the above loco but absolutely stumped as to how to fit the speaker in the tender. There are no clear instructions about this either with the decoder or the Loco boxes.I cannot find any useful info by Googling either. Can anyoen help please? Link to comment Share on other sites More sharing options...
Howbi Posted January 5, 2019 Share Posted January 5, 2019 Hi Johnbw, welcome to the Forum...........if your tender looks like this King class........first remove the 2 screws holding the weight, feed the speaker through the hole in the weight and place the speaker (facing downwards) into the recess provided. Replace the weight and screws......plug in the decoder and all should work........HB/media/tinymce_upload/02319a3cfd4b4cfdf12fc540f2e2bbf4.png Link to comment Share on other sites More sharing options...
96RAF Posted January 6, 2019 Share Posted January 6, 2019 Further to the above advice, if your speaker comes in a plastic enclosure then that will not fit under the weight and will have to be put aside for another project. Just fit the speaker on its own.You can also improve the sound quality by glueing a piece of card over the hole in the weight to isolate the top and bottom of the speaker.Rob Link to comment Share on other sites More sharing options...
2e0dtoeric Posted January 6, 2019 Share Posted January 6, 2019 Some reports say the TTS speaker isn't much good anyway, and they fitted an alternative 'sugar-cube' speaker of matching impedence and wattage.The Hornby speaker tends to be a 'one-size-fits-all' solution. Link to comment Share on other sites More sharing options...
morairamike Posted January 6, 2019 Share Posted January 6, 2019 If you can fit the decoder in the loco and use a sugar cube speaker in the loco mounted under the chimney. The resulting sound is much better. Link to comment Share on other sites More sharing options...
96RAF Posted January 6, 2019 Share Posted January 6, 2019 This shows a micro cube speaker sitting on the front chassis of an MN under the funnel with the TTS decoder plugged in just behind it and slipped into the smokebox area of the body. Don’t forget to drill out the funnel AFAP. Rob/media/tinymce_upload/40fbfb7799deb36f99e12bbadfaf98ab.png Link to comment Share on other sites More sharing options...
Rog RJ Posted January 6, 2019 Share Posted January 6, 2019 @RAF96AFAP ??? Link to comment Share on other sites More sharing options...
2e0dtoeric Posted January 6, 2019 Share Posted January 6, 2019 AFAP = As Far As Possible! Link to comment Share on other sites More sharing options...
Howbi Posted January 6, 2019 Share Posted January 6, 2019 This shows the actual installation...........HB/media/tinymce_upload/2e94cb4321b8cd72d364f80d3a5eed59.JPG Link to comment Share on other sites More sharing options...
Rog RJ Posted January 6, 2019 Share Posted January 6, 2019 AFAP = As Far As Possible! Thanks. Not come across that before. Link to comment Share on other sites More sharing options...
walkingthedog Posted January 6, 2019 Share Posted January 6, 2019 Never seen that before. How can you drill the chimney as far as possible. You either drill it right through or not at all. 🤔 Link to comment Share on other sites More sharing options...
Chrissaf Posted January 6, 2019 Share Posted January 6, 2019 Maybe Rob meant diameter wise, not depth. To let more sound out. Just a thought. Link to comment Share on other sites More sharing options...
walkingthedog Posted January 6, 2019 Share Posted January 6, 2019 Could be, but chimneys can be very fragile and I once had one detatch as I drilled it. 😮 Link to comment Share on other sites More sharing options...
96RAF Posted January 7, 2019 Share Posted January 7, 2019 Pedantic pedant......of course I meant internal diameter and to drill clear through. Do I need to say vertically as well. How else would the sound get out.Now is not a good time to bait me with me silly questions. I am in the middle of moving. Selling a house here can be very rapid and completed in a day if necessary. I have lots of things to do and the forum may not be top of my list this week.Rob Link to comment Share on other sites More sharing options...
