NSE 50 Posted June 20, 2019 Share Posted June 20, 2019 HiIf I select F1 to activate the TTS sound while the locomotive is stationary all lights etc function correctly but it will not move until F1 is toggled off again. If F1 is selected whilst moving there is no sound but loco continues to respond to dcc handset until it is brought to a stand.I have tested the speaker in a different loco and it works perfectly. I have tried the TTS chip in 3 different locos with the same result. I have tried a CV 8 sound reset by entering 5 and a full reset by entering 8. I am able to write loco ID etc to the chip.Any ideas would be appreciated.Thanks Link to comment Share on other sites More sharing options...
Sultan Posted June 20, 2019 Share Posted June 20, 2019 I would suggest returning the chip to the supplier or you could contact Hornby Customer Service who can be very useful with CVs etc oin TTS decoders. Link to comment Share on other sites More sharing options...
96RAF Posted June 20, 2019 Share Posted June 20, 2019 Which controller are you using and at what revision status. Link to comment Share on other sites More sharing options...
Triumph speedtriple Posted June 20, 2019 Share Posted June 20, 2019 To me it seems thats theres not enough power, had this with my DCC starter set where it comes with a 1 amp power supply fixed when upgradedto the 4 amp supply Link to comment Share on other sites More sharing options...
