Davjan Posted June 29, 2019 Share Posted June 29, 2019 Hi guysIn design mode I am trying to add the arrows but get problems.I left click the square that contains the piece of track to be marked,then right click within the square which brings down the pop-up for selecting direction or remove the arrow.This does not often work either not placing it and the normal pointer changes to one with 4 points or places the indicator within the square but not within the track itself.Has anybody had this problem ?DAVJAN Link to comment Share on other sites More sharing options...
RB51 Posted June 29, 2019 Share Posted June 29, 2019 Personally speaking I found those arrows so problematic to correctly place [and then remove] I decided to do without them. My new layout has little use for them as it is an end to end so all lines are two way. R- Link to comment Share on other sites More sharing options...
96RAF Posted June 29, 2019 Share Posted June 29, 2019 I reported the same problem some years ago and it appears to still be prevelant. I gave up on it many blue moons ago. Link to comment Share on other sites More sharing options...
Davjan Posted June 30, 2019 Author Share Posted June 30, 2019 Thanks Raf and Roger for you commentsI inserted them some 4 years ago as I have 2 track buses for an Up line and a Down line on layout that is 16 by 10 feet and all seemed correctly positioned until the latest update now they are all over the place.They do help any visitors when using the layout.I have reported it to the team but if nothing can be done I will have to delete the lot but on some when getting the drop-down some do not respond to the REMOVE button if clicked.DAVJAN Link to comment Share on other sites More sharing options...
96RAF Posted June 30, 2019 Share Posted June 30, 2019 From memory even deleting the single track elements didn’t lose the arrows. Maybe I did it by drawing a cartouche around several track elements and deleting the batch in toto., then putting back the plain track elements. I know at the time it was a faffy way of getting there, so I never used direction arrows again. The locos know which way they are facing. Link to comment Share on other sites More sharing options...
RB51 Posted June 30, 2019 Share Posted June 30, 2019 some do not respond to the REMOVE button if clicked That is one of the most worrying aspects of the coding. R- Link to comment Share on other sites More sharing options...
